Seiko Melodies in Motion Clock Logo
A
Anonymous Posted on Nov 23, 2013
Will not turn time piece but will keep time
I have two melodies in motion clocks that work fine but neither will turn the figurines but will play the music on time
UsedClockPartsdotCom
Level 3:
  • Seiko Master 277 Answers
  • Posted on Jan 25, 2017
Seiko Master
Level 3:
Answers
277
Questions
0
Helped
147028
Points
4537
I would take it to a clock repair shop.
UsedClockparts.com
2 Related Answers
Anonymous
  • Posted on Apr 04, 2011
SOURCE: My clock still keeps time, but no motion nor
I have a Seiko musical motion clock that I bought in Japan a few years ago. For setting the time it has a "A" and "B" button that you hold down? I dont have the instructions to set the time. It says "Radio Controlled" but the time was always manually set before by luck trial and error. How do you set the time?
Anonymous
  • 69 Answers
  • Posted on Jun 17, 2011
SOURCE: I need to know how
i had that clock hre. and all the insides are special from seiko, i would send it to them. the movement is encased in plastic and some lever rods attached to them . may be worth sending
Seiko Melodies in Motion Clock playes at all hours even when it is dark in the house. Is there a way to see if light sensor is broke?
From memory, there is a switch on the back for music all the time or not at night based on ambient light. They all have it.
https://www.google.com/search?q=Seiko+Melodies+in+Motion+Clock+manual
Seiko Clocks - Westminster Owners Instructions
The Clock Depot https://www.theclockdepot.com > seiko_westminster_c...
NAMES AND LOCATION OF OPERATIONAL PARTS. Seiko Clock Manual 1 - Hands setting disk. 2 - Night time silencer. 3 - Chime melody switch.
Instructions for Seiko Dual Chime Quartz Clock Movements
Norkro Clock Company https://norkro.com > pages > instructions-for-seiko-du...
Move the night chime selector switch to the left most position. Moving in a clockwise direction, use the rear-mounted hand set to advance the hands until they ...
Chime Clock Instructions ' Setting Time ' Pendulum Clocks
theclockdr.com https://theclockdr.com > clock-instructions
Clocks with more than one chime melody: Change the tune selector only when the clock is not chiming. Timekeeping Accuracy: This type of clock will be able to
2answers
Need a manual for a Seiko melody in motion wall click. Model # QXM123BRH
Here is a manual for the Seiko Melody in Motion Wall Clock, Model # QXM123BRH:
Getting Started
  • Insert one "AA" size alkaline battery into the clock's battery compartment.
  • Set the clock to the correct time by pulling out the time-setting knob and turning it clockwise or counterclockwise to set the time.
  • Push the knob back in to the "Lock" position to finish setting the time.
Melody Selection
  • Press the "Demo" button on the clock's front panel to listen to all the available melodies.
  • To select a specific melody, press the "Melody" button repeatedly until the desired melody plays.
Volume Control
  • To adjust the volume of the melody, press the "Volume" button repeatedly until the desired volume level is reached.
Light Sensor
  • The clock is equipped with a light sensor that will automatically turn off the sound and motion sensors when the room is dark.
  • To disable the light sensor, push and hold the "Light Sensor" button for approximately 5 seconds until the "OFF" indicator appears on the display.
  • To enable the light sensor, push and hold the "Light Sensor" button again for approximately 5 seconds until the "ON" indicator appears on the display.
Motion Sensor
  • The clock is equipped with a motion sensor that will detect movement in front of the clock and activate the sound and motion sensors.
  • To disable the motion sensor, push and hold the "Motion Sensor" button for approximately 5 seconds until the "OFF" indicator appears on the display.
  • To enable the motion sensor, push and hold the "Motion Sensor" button again for approximately 5 seconds until the "ON" indicator appears on the display.
Nighttime Silencer
  • The clock is equipped with a nighttime silencer that will automatically turn off the sound and motion sensors during a designated period of time.
  • To set the nighttime silencer, push and hold the "Nighttime Silencer" button for approximately 5 seconds until the "SET" indicator appears on the display.
  • Press the "Melody" button to select the start time for the nighttime silencer.
  • Press the "Volume" button to select the end time for the nighttime silencer.
  • Push the "Nighttime Silencer" button again to save the settings and exit the nighttime silencer mode.
Troubleshooting
  • If the clock does not operate properly, try replacing the battery with a new one.
  • If the clock still does not operate properly, contact Seiko Customer Service for assistance.
Note: This manual is for general information purposes only and may not cover all features and functions of the Seiko Melody in Motion Wall Clock, Model # QXM123BRH. Please refer to the manufacturer's instructions for complete information on how to operate and maintain your clock.
Mar 03, 2023 • Home
Where can I get my melody in motion figurines repaired
Main Page
May 22, 2016 • Home
Why will my clockl no longer play song or move
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling
UsedClockParts.com
I have a Seiko Melodies wall clock, reference #= QXM1395RH, I purchased in 2006 from an Ace Hardware dealer. It has worked beautifully until a couple of months ago when the parts that open up to the...
I'm not sure if you still have your clock but I just fixed mine, same issues as yours, if you open the back up and there are two black little boxes, the left box controls the face opening and closing, take the two screws off the opposite corners, the white independent wheel has worn the whole larger, so I glued like a little brass piece yo ouch the stem of the wheel back in the original whole just make sure you don't get glue in stem, the piece you glue should be glued in the opposite side, we used gorilla glue, Just a small dab
3helpful
2answers
My seiko musical wall clock doesn't play music anymore
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
Top Seiko Home Experts
ZJ Limited
ZJ Limited
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Seiko Home Expert? Answer questions, earn points and help others
