The Volume on computer just went off one day.When I went to The Icon "My Computer"and tryed to move the volume up from mute,Bar would not move.Icon on bottom of computer no loner exist.
I don't think you're stuck on mute I think you're having problems with your sound card. Go to device manager; if there is a yellow or red sign on sound then right click and try reinstall driver. Let me know if you have any questions. Pls rate this solution.
What type of laptop HP , ASUS , COMPAQ , ACER ?.......... Up the
Volume on My HP Laptop
Open the "Start" menu and click on the
"Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either
"Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the
slider.
If you need to decrease the volume, simply move the slider
bar down.
Click on "OK" when finished and close the
"Control Panel" window.
Click on the speaker icon in the bottom-right corner of the
screen for a faster volume adjustment. Simply move the slider bar up to
increase the volume and move it back down to decrease the volume.
Volume on an Acer
Laptop
Acer laptops are typically sold with
pre-installed Windows operating systems that offer sound-adjustment features
for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem
with external speakers or headphones to increase the volume, as well as mute
all sound on the laptop.
If the computer should output an unusually low volume,
fixing the problem may be no more involved than sliding a control switch with
the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner
to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to
drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control
to open another window with volume controls for "Speakers" and
"Applications," adjusting each slide control upward to increase the
volume.
Be sure the speaker icon below each control is not
accidentally muted.
Click once on each speaker icon to remove the red circle
with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the
lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select
"Adjust Sounds" from the Hardware and Sounds category.
Right click on the Speakers/Headphones icon on the lower right of your screen and select "Troubleshoot sound problems". Windows 10 will repair it for you.
Click on the arrow next to the clock on the bottom right side of your screen. Find the icon for volume and double click on it. If the speaker is set to mute, double click it to release it. Then use your mouse to move the slide up to increase the volume.
if this does not solve your issue, contact me or use the comment or reply link to report any problems.
if the little x over the volume bar is still stuck after moving it up you may have to hit the function key (fn) on your laptop and hit one of the F1-F12 KEYS that look like a mute or volume symbol also there should be a mute button on the laptop itself. if all that fails. go to (xp) right click on my computer -device manager-and see if you have a red or yellow x over your sound sound devices (win vista or 7) go to computer, sys prop on the top then device manager. if you see any of htose yellow or red warnings you will need to re-download the audio drivers from acer website Let me know if this helped.
ight click my computer in the desktop and click properties then hardware then device manager then expand the sound vedio and game controller if you find a yellow question mark on it reinstall the driver if there is no yellow question mark go to the taskbat and right click the speaker icon then click open the volume control and look if the control volume is muted if muted remove them and move the slide to high
first right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
if your connection is right. double click speaker icon in the taskbar->dialoguebox volume control->uncheck all checkbox->adjust volume for wave in volume control->ok
2..IF NOT SELECT OPTION IN VOLUME CONTROL DIALOGUE BOX->ADVANCED CONTROL->UN CHECK PC SEAKER MUTE
in your computer trey you see a red speaker icon (reltek hd adio sound output)(if cant see read downside). doble click this icon and you see a sound setting box. you see upside 5 option(sound effect , mixer , aodio I/O etc.) choose MIXER and you see two option in upside PLAY BAKE and downside RECORD see upside you see option subwoofer, center line volume . front mic, mic volume and cd volume. you see that front mic and mic volume is muted. remove mute and enjoy (if you cant see icon go to this address:- My Computer C:\Program Files\Realtek\InstallShield. in this location you see two red speaker icon. dobble click the icon "RTHDCPL"and now you see the icon)
Try checking to see to make sure that the audio jacks are plugged into the right ports. Also, check to make sure that nothing is muted, and that volume is up ( I've actually went for sound without a day after moving my computer because I forgot I had muted and turned my volume all the way down the day before xD )
Anyway, I hope this helps, and let me know if it doesn't.
Oh, and one last thing, make sure that your speakers are set as the primary output devices. If you have 3rd party audio drivers, sometimes you have to set what audio output is going through.
Have you tried going into the speaker settings? We'll assume with a new PC you have Vista installed, click the speaker icon on the right side of the tray, and selecting "Mixer" will enable access to volume control for the output devices and for applications.
If no speaker icon is visible To check the volume controls in Windows Vista, click Start and then click Control Panel. Choose Hardware And Sound and then click Adjust System Volume under the Sound section. The Volume Mixer window will open, and you should see volume sliders for Device and Applications. Click and drag the sliders to view the volume level percentages. If the speaker icons show a circle with a red slash, click the icon so the speakers are no longer muted.
Furthermore, you’ll want to double-check all of your master
volume and mute settings.
