20 Most Recent Dell Inspiron 4000 Notebook Questions & Answers
Wireless adapter does not work
there is no driver installed for your adapter. check in device manager click on network adapters.you may have to connect to internet with ethernet cord before you can download a driver for your adapter.
1/11/2015 7:25:16 PM • Dell Inspiron... • Answered on Jan 11, 2015
The fan on my Dell Inspiron 4000 is always running.
a couple suggestions:
try starting in safe mode and see if it does it still. It could be that you have some background program like Windows update or that new Windows active search function, which spends copious amounts of processor time cataloging your entire computer. Some anti-virus programs will do the same and eat up processor time. I'd try shutting down as many of these background processes to see what (or what combination) is causing the problem.
If this doesn't work, you might have a bad connection with your heatsink, which would cause your computer to stay at or your fan might be going bad, causing it to get really loud.
I'm not going to go into the possibility of it being used on a lap or bed or carpet where the fan intake vent is getting blocked. I know you've eliminated this as a possibility. Right?
3/27/2014 2:31:41 PM • Dell Inspiron... • Answered on Mar 27, 2014
3answers
Hard drive not detected
this sounds like a classic case of hardware failure, try taking the hard out and putting back in again, also check in the bios to see if the hard drive has been detected. if you get the same result the hard drive has failed and you will need another one
11/15/2012 5:42:29 AM • Dell Inspiron... • Answered on Nov 15, 2012
I want to download microsoft Power point
To download a legal copy from Microsoft. Click hereAnd for the other from 1337x using Vuze to download. Click here.Hope this Helps!
8/25/2012 5:08:25 PM • Dell Inspiron... • Answered on Aug 25, 2012
Driver for Windows ME for a INTEL WiFi PCI Card B2200BG WF03?
Try e-bay or a second hand shop. ME is unfortunately no longer supported by Microsoft
6/13/2012 11:05:53 PM • Dell Inspiron... • Answered on Jun 13, 2012
Half screen no display
Replace lsc screen?
3/31/2012 11:20:16 AM • Dell Inspiron... • Answered on Mar 31, 2012
I have 3 operating systems installed so i need to lose two of them dont ask cos i dont know how they got there
I recommend you do a clean reinstall XP Pro using the Windows XP Pro installation CD. Delete all the partitions and create a new partition.
This is generally how your format the hard disk and install Windows. First you need a Windows XP or Windows Vista installation CD and the product installation code, which is printed on the Windows label on the bottom of your laptop. Boot up with the Windows installation CD start and follow the instructions to install Windows. Next Delete the existing Windows partition. Next Create a new partition. Next format this new partition - Format the partition in NTFS not a quick format. This will prepare the Windows for a clean install. Next create a User(name) and company name (normally Home is all you need). Further into the installation, you will be required to put in the Installation code.
During the final stages of installation you need to create an User or Users that will use this computer.
When you finished installing Windows you need to install the laptop's device drivers. You need to use a computer with Internet access to download these drivers from the laptop manufacturer's WEB site and install these drivers on your laptop. Next connect a LAN cable to the LAN port from your computer to your DSL or cable modem and you need to Activate the Windows installation on the Microsoft WEB site. Next up need to upgrade Windows from the Microsoft WEB site including Service pack. Next you need to install your programs
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
3/31/2012 9:21:36 AM • Dell Inspiron... • Answered on Mar 31, 2012
I CANT DOWNLOAD
have you tried doing a virus scan?you could try uninstalling Internet explorer by add/remove program and reinstalling from software disk
3/30/2012 5:37:16 PM • Dell Inspiron... • Answered on Mar 30, 2012
PXE-E05:The LAN adapter's configuration is
reinstall the lan driver of your laptop and that will fix the or overwrite the corrupted driver.
7/10/2011 5:18:36 AM • Dell Inspiron... • Answered on Jul 10, 2011
Hello Dear! My laptop dell C
maybe perhaps the audio driver is not well compactible with you laptop all you need to do is to download the driver that is compatible with yor laptop just go to this link content.dell.com/_layouts/xdb.ashx?global:apps2:sdc and download the driver that is compactible with your laptop
please comment on this post stating how it help you with your laptop
1/7/2011 9:35:40 AM • Dell Inspiron... • Answered on Jan 07, 2011
My dell inspiron 4000 the
Most dell you can just replace the fan.
1/4/2011 11:30:56 PM • Dell Inspiron... • Answered on Jan 04, 2011
Power on laptop fan is
Remove the battery, press power button to drain power, put battery back on and turn the laptop on again. This usually clear is, but if it doesn't let me know and I will follow up.
Thanks for using Fixya!
11/19/2010 11:43:57 AM • Dell Inspiron... • Answered on Nov 19, 2010
Is this a virus?
Try blow out the dust around the fan.
not sure what roadrunner is either. so to check if your PC is infected, go google panda scan (free) install their software n do a online scan. It wont get rid of it if it even is but will tell you if your PC is infect and were to go to find it on your computer.
11/2/2010 8:09:59 PM • Dell Inspiron... • Answered on Nov 02, 2010
When you type the letter
Usually it's because the number lock is locked on.
Check your keyboard carefully for a key that reads "num lock" press it once and you should be good to go :)
p.s. If it's in blue sometimes you need to press FN + 'num lock"
Hope this helps!
10/14/2010 3:36:30 AM • Dell Inspiron... • Answered on Oct 14, 2010
My inspiron 4000 won't start up. i replaced cord;
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
9/19/2010 2:55:29 AM • Dell Inspiron... • Answered on Sep 19, 2010
Hi my i pad
Usally you have a function button to turn it on and off, keep the FN button presseed down and press the one above the number which looks like a mousepad this should turn it back on, if not uninstall the mouse pad and let the computer reinstall it on a reboot.
9/3/2010 12:54:14 PM • Dell Inspiron... • Answered on Sep 03, 2010
I wanted to install a software on my dell inspiron
Hello and Welcome to FixYa!
The standard procedure for it is to run the Disk Clean up utility, it will check for the temp files, chkdsk files and other offline files that can create enough space for the driver. You can see the Disk Cleanup procedure here.
If after the cleanup there isn't enough space then there is no other option either to extend the drive or to uninstall few software. To uninstall the installed software you can use the Control Panel.
I hope you will have a clearer picture now, If you are having problem, do ask me, I'm here to Help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
7/31/2010 7:21:25 AM • Dell Inspiron... • Answered on Jul 31, 2010
Dell Inspiron 4000 Notebook Logo
Popular Tags
76 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
3 operating systems installed need lose
  • Computers & Internet
