HELP! NEED A RESET BIOS PASSWORD AND RESET PAWSSWORD ADMINISTRATEUR FOR MY LENOVO N500!
SOURCE: lenovo n500 major issues
For fdisk utility Boot from xp bootable cd,Go to the repair option.In this section you have to mention username & password.Then start Fdisk /f utility.
SOURCE: Lenovo n500 forgot bios password
Hello, If you forgot your BIOS password,do not worry, you can reset your system back without requesting a BIOS password,Simply unscrew your laptop and get the motherboard of your laptop, locate the CMOS battery on the motherboard and remove for sometime for the battery to discharge say 4-10minutes,or better still if you can locate the jumpers for the BIOS and reset it,the BIOS password will be removed.It is the battery that keeps the BIOS chip alive by suppling it power,if power is not supplied to this chip,then the information on it will be lost. So, remove the battery for some minutes or reset your BIOS jumper on the motherboard WISH YOU THE BEST.
SOURCE: i am forgot bios password
The only simple way to Erase the forgotten Bios Password is to Reset the CMOS Battery.
SOURCE: bios password for Lenovo T400
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type Youll notice the password is gone. If this fails try typing At command prompt type debug If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Please select an option:
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Q
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup.
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
Hope this helps.
