Server
Hey there chandru 2020, the configuration problem which you are experiencing is related to the positioning of your ram in the appropriate slots. Servers work with matching pairs of ram, installed in either two, four or eight sticks of memory. The placement of less than a full set , in your case two minimum is also very specific. You should go to the Dell website to access configuration diagrams for your server model. Also check to ensure your ram is compatible, and try installing just one pair at a time. There is also a possibility that a blank may need to be inserted in empty dimms. I hope this helps. Good Luck!
