Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool LA6800XTWO will not drain or spin
My whirlpool imperial washer fills with water, but the water is not pumped out nor does it spin. The timer advances normally. When it gets time for the water to be pumped out or for the basket to spin I hear a moderately loud hum (like the motor is trying to spin but can't). What do you think is wrong.
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on May 04, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
Helped
11942
Points
134
Need a new drain pump. I just had this problem. found a drain pump on ebay for 60. Replaced and running mint again. don't keep trying or you will burn out your motor.
LA6800XTWO Whirlpool washer: tub fills and empties but no spin or agitation
sounds like the motor or clutch pack is bad if so its a expensive fix
Washer fills up and starts. Once it gets to rinse cycle and spin cycle is makes a loud humming noise but wont spin. If i open the top lid and wait a second or two and close it, it starts the cycle. Been...
If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
Fills with waters starts making a buzzing sound
Check to see if there is something(sock) in the pump. If not, try spin washer with pump hanging down, but not with hoses off.
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
2answers
My washer is not draining or spinning. It fills & agitates. whirlpool LLR8245DQ0 . i LOWERED THE DRAIN HOSE AND DRAINED IT BUT IT STILL DIDN'T SPIN
It may be the wire from pressure switch is either not receiving power through the switch or it may be broken? If that is ok then check timer.
I have a Whirlpool LA6800XTWO washer. When I run it, it fills with water, but it does not spin, agitate, or pump the water out. When it gets to a point that it should do one of the above things all I...
sounds like a broken coupler, looking at your wiring diagram this unit would agitate with lid up right? then lid sw is not your problem, if it does not drain either then motor must be not turning over, so i would check the capacitor first. (it on the back panel behind the tub)
1helpful
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
3helpful
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • 0helpful
    Whirlpool super capacity imperial
    We have a drain issue it seems like. I would first check the drain hose to make sure that an air gap exists to prevent drain water siphoning into the machine and then run a rinse and spin empty to see if this helps. Second is to check spin speed and pump condition as these two can work together to create a problem similar to yours.
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
