Konica Minolta bizhub 350 All-In-One Laser Printer Logo
A
Anonymous Posted on Nov 12, 2013
2557 error codes in C454e - Konica Minolta bizhub 350 All-In-One Laser Printer
Ubaid abid
Level 2:
Guru:
  • Expert 164 Answers
  • Posted on Apr 20, 2019
Ubaid abid
Expert
Level 2:
Guru:
Answers
164
Questions
0
Helped
123060
Points
609
Fix error 111 code on Minolta c454e
missing number in the error code it will be c-XXXX
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
C-2557
C 2557 - ATDC sensor error.You need to replace the developer in imaging unit.
Ineo 362 error code 2557
replace the drum and developer
Error Code C-2557
replace the black image unit
1helpful
I have an error code C-2557 on this Biz 350 with the finisher, without the the finisher m/c works fine
C-2557 ATDC sensor malfunction.Enter in the service mode press following keys:
Utility-Metercount-Details-STOP-0-0-Stop-0-1-press 00000000 press Enter in Tech. mode select Printer than select ATDC gain and read the ATDC current value.If the value is situate 150-160 increase the value to 164-174 (to change the value press C and entering the new value)return in the copy mode turn OFF the copier open the rigy door than close and turn ON the copier and make a few copies.If the error persist discrease the ATDC value and make some copies.If the code persist change the developer .Before change the developer reset the special parts counter I/U counter,developer.After change the developer perform F8 and verify the new value to ATDC gain and notice.
2helpful
Error code c25507
error code 2557 is ATDC Sensor Failure, low density
15helpful
4answers
I have a C-2557 code on a bizhub C450
interesting... this information is covered in detail in this post http://www.fixya.com/support/t1232734-bizhub_250_malfunction_code_c2557_help
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
4helpful
Konica minolta is getting error c2557, before this it was saying
c-2557 code has to do with you black toner bottle.
how handy are you?
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
