Sylvania 6520FDG 20" TV/DVD Combo Logo
tom thomas Posted on Nov 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote code need to reset channel search cable need to get menue
Level 3:
Top Expert:
  • Sylvania Master 76,851 Answers
  • Posted on Nov 09, 2013
Sylvania Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008447
Points
237762
0038,0031,0036 are the common codes user for Sylvania brand TVs. Try these codes. If you wish to get more details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
2answers
How to do channel search
go to the Menu and you should find it.
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
I only get channels 2 through 22, 23 on up - nothing
this is not a problem from remote control. You must adjut the TV program go to the MENu, run the scanner, for add the program TV.Try to reach you supplier TV cable for explain then, if there are not problem witht the receiver box.
however if you need to reset the code program go for free download:
www.fitness.manualsonline.com or www .remotecodelist.com
sincerely. God bless you
I have removed all cable boxes from my home. I cannot get the tv remote to change channels. I was told by the cable tech that I needed to do a channel search. How do I do that?
Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here: http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: http://www.sanyotv.com/DS19330%20%28ESF%29%203764--.pdf . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
3answers
How do you scan the channels on the PDH42L40? I need to go to a certain channel on the TV to get my Dish Network to work. It is not hooked directly into a box, it is on a secondary receiver. Please...
hello and good day to you!!!!
if you wish to scan your TV to go for a certain channels..
you need to reset auto scan on your TV...
this are the procedure on how to reset auto scan...
  1. Get your remote control..
  2. press the menu button on your remote
  3. go to the settings..
  4. try to find the auto search.
  5. after you find the auto search press enter to scan the channels.
Note: Please complete the 100% scan for better results..
2helpful
I have a Sanyo DP26746 TV. I pushed the reset button in error and am unable to get to any other screen. It wants to look for HD channels. Since I only use a satellite service it can't find any. Help! I...
First of all make sure all the leads are connected to the TV.
Press the reset button on the remote twice (this will clear all previous settings) and perform a channel search and create new ones.
Now you will need to perform an all channel search.
Press the Menu key to display the main menu.
Use the cursor up/down keys on the remote and select "All Channel Search" and press enter. Use the cursor key to select yes and press enter.
Now you may need to perform a digital cable search to pick up your satelite digital signal.
Press the tuner key on the remote and then the menu key.
Use the cursor key to select Digital cable search and press enter.
Now the TV should scan for a digital signal
Good luck and kind regards.
I need the code to do an auto channel search for my lg tv so i can go up and down from channel to channel instead of typing the number to the channel in
Your auto channel search should be in your menu on the TV. Find your menu button on the front of your TV or on the remote.Make sure before you do a auto search you set your TV to cable, that can also be be done through your menu screen. If you can change the channels on the remote and control the volume your remote is already programmed.
Need to reset sanyo DP26647 without remote control
I got it to scan and finally have all my channels. I just kept entering menu & hitting down arrow and it just started scanning after about 5 or 6 attempts. Very unscientific but it worked. I have ordered a replacement remote.
2answers
How do you get to the set up menu w/out a remote
hold down vol down on the remote and push 1 on the universal remote. this should turn your tv off and reset it to factory defaults alowing acess to all cable channels
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
