20 Most Recent
Quasar SP-2725 27" TV Questions & Answers
Narrow screen
You're discussing about the less in height to picture; I assume. How old is this TV? If it is older than 3 years or so, you have to check all the electrolytic capacitors used at its vertical scan output section circuit. There will be usually 5 or 6 of it. Replace all of it at one time, and check. You have to open the TV, and have to solder these capacitors, and solder with new ones in place. It will be better to contact any service technician. The components said above won't cost more. Mind about the service charges. If you wish to get some details, check the site linked here.
http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in '
Mosaic' view. It will make search easy.
The vertical amplifier colasped to a single
change the horizontal transistor,the yoke or the flyback,also the vertical ic.there is also a diode at the base of the HOT you can check that also if it is open change it.
My unviersal remote wont work
No,all universal remotes have it limited and difference troubles in each of tvs it uses.Try website like Remotes.com to buy an original remote.
Aspect Ratio is off
east west correction cirket is faulty change/check releated components near the horizentle yoke connection
