You can either program one of the buttons for this task, or use Feature 70. Find more info in user manual: Nortel networks phone manual t7208
This is usually programmed as one of the 'soft' buttons down the right hand side of the device - subject to the programming of your phone / and the system.
Usually the T7208 is connected to the BCM range of PBX systems - in which case, to transfer a call, you'd use Feature 70. You could, of course, program this into one of the buttons yourself, so you only have to press one button to do so.
Hope this is of use to you. :)
SOURCE: password issues
To reset a subscriber mailbox press feature 983, enter in log (default 1020000), on the 3 soft keys bolow the the screen press mbox,chng, enter extension number of the locked mailbox, press reset at the reset password prompt.press rls key
SOURCE: How do I listen to by mesasges on a Nortel T7208
To access your voice mail messages either press your open voice mail key (if programmed) or enter feature 981.
SOURCE: T7208 Nortel Norstar phone system - how to
unfortunately when a message is deleted... it is deleted unless you have a back up
SOURCE: cant change time and date on nortel t7208 phone
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Testimonial: "With clarification that I gave on steps I took and what were results within three questions figured out the problem and solved it. Thank you very muc"
SOURCE: I have a Nortel T7208 phone. It shows "Message fo...
I have a Nortel T7208 phone. It shows "message for you" and the light is on but when I open my vm. I don not have a message how do I get rid of this?
