Blaupunkt Miami Beach CD51 CD Player Logo
Mantas Petrauskas Posted on Oct 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't eject CD
Well, I've read in the manual, that you have to just click the flip panel button and it should eject automatically, but it doesn't. All it does it just flips open the face of the stereo an stops playing, as if it shuts off.. I got it this way, and there's a CD in it that I'd like to remove.. Please give me some advice or something..
fred j
Level 2:
Scholar:
  • Expert 127 Answers
  • Posted on Oct 29, 2013
fred j
Expert
Level 2:
Scholar:
Answers
127
Questions
0
Helped
32055
Points
353
Well the owner manual says to press button 9 and then flip down the face of the radio and it eject the cd. not just flip the face down . here is a link to the eject instructions..how to eject the cd on a miami beach cd51 have more questions email me at [email protected]
Testimonial: "The button 9 is the button that flips open the panel. I've read the manual, and I'm thinking it might be a hardware issue. If I could just find out where's the trigger for the CD ejection, I might be able to fix it if its broken or maybe just needs some adjustments, but for now, I don't even know what triggers the ejection. Is there a button that presses it self when the panel flips open or something, that is what I need :) but thanks either way for replying."
My Victrola VTA-200B CD player isn't working properly
The player is having problems reading the CD. This can be for several reasons. Remove the CD and see if a different one has the same problem. This way you can find out if it’s the player or just the CD. Wipe off the smudges on the back of cd. If cd has too many scratches or smudges it won’t play. There can be many other reasons why it doesn’t play.
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
I have a dell vostro 1510 and can't get my cd out. When I click on the eject button, it lights up, but nothing happens.
What you might try is going to "My Computer" or "Computer", right clicking on the CD drive, and clicking "Eject". If that doesn't work, go find yourself a fairly small paper clip, stretch it out, and use it to poke that little hole on the disc drive itself that is a manual eject device.
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
1helpful
My cd is stuck and the eject button won't eject it. Is there any way I can get it out?
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
I have an LCD/ DVD combo and the DVD won't come out. The tv still reads the DVD but won't eject it. I've tried on the remote and the unit :(
then there is a problem with your cd case .........................................................
ON THE BACK OF DVD THERE IS A WIRE OR SUM PIECE PULLED IT BY USING SOM CLIP THEN THE DVD'S DOOR OPEN EASILY..........
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Dan
Doesn t reading the cd
hey,
also mention how old are ur CDJ and does it play original cds. Did you get any error code.
thx
djajay
My LG CD Writer ejects automatically without any operations...
This is normally as sign that the writer is faulty, especially if ejecting on your pc's start up. Just go through this first to check if it's just a driver fault. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
