20 Most Recent
ZT Group Cisnet PC Desktop Questions & Answers
Hello, I have a problem
Somewhere on the computer is the access code to re-install and activate XP from Microsoft, if it was still available. But it's not. Do you really want to buy XP again? Or pay for newer software on an 11 y/o PC? Recommend you put that money into upgrade. New or used.
How do i know if my usb port it working
plug a device into it and see, eg a flash memory stick. If it doesn't work try different usb socket
20.December.2014
ps there be a number of reasons why your usb port doesn't seem to be working If it doesn't. Some are software related
Can i upgrade intel 8280 1eb usb universal host controler to a usb 2.0 ?
The following lines in your USB controller discriptions, means that you have
ISB 2.0:
"Intel(R) 8280 1DB/DBM USB 2.0 Enhanced Host Controller - 24CD"
Click on Link to Add MS to your News Reader: news://msnews.microsoft.com
Basically its already usb 2.0 and you don't need to upgrade it anymore
Hope I was able to help you thanks
I own a C ISNET CI-3003X and it has a red light
It could be a defective or dirty video card. But in the some cases, where built-in graphics is used (no video card, built-in to motherboard) it is the memory (RAM) that is causing the problem.
Try removing your video card (if you have any) or memory from the board.
Video card removal instructions:
http://bit.ly/1m0jwb3
Memory removal instructions:
http://bit.ly/1s5svYr
Clean the pins (gold contacts) with a rubber pencil eraser. Install the memory or the video card back to the board & power-on. If this doesn't work, replace the defective unit.
You may also try cleaning the internals of the computer using a non-static brush & a can of compressed air.
What kind of ram do i need
Yes, there is. You can find information about it here:
http://en.wikipedia.org/wiki/DDR_SDRAM
If you want real help, know your motherboard's brand & model so we could check what type of RAM it supports. If you can't find out, download and install speccy or aida64. It could give detailed report about the specs of your pc.
Hope this helps.
My boot menu key is disabled how to enable it
when the computer boots up use either F2 , F4 , F6, or F8 sometimes you need to press both F4 and F6 together and once in the boot menu enable the options under boot menu and restart the pc
How to access boot option my boot option is disabled
Windows operating systems support a variety of boot options on the Windows Advanced Options Menu that allow you boot your computer based on your need.
They support boot options such as Safe Mode, which is generally best for troubleshooting and virus removals; or the Safe Mode with Networking, which allows to use an Internet connection while troubleshooting system problems.
Within seconds, you can access the boot menu and select the option that works well for the task you want to accomplish.
Shut down all currently running programs and restart your computer.
Press "F8" repeatedly before the Windows icon shows up on your screen.
This will bring you to the "Windows Advance Options Menu."
Scroll down and select the boot option you want.
Press "Enter."You can select from "Safe Mode" "Safe Mode with Networking" or your regular booting option.
Choose the boot option based on your need.
For troubleshooting, it is advisable to select "Safe Mode" because only a certain amount of drivers and resources run allowing you to resolve issues
Touchpad Scrolling
The scrolling feature on a laptop touchpad can take some
getting used to, which causes some users to disable the feature.
Whether scrolling was intentionally turned off or never
enabled on the laptop, it can easily be turned on from the "Mouse
Properties" menu.
Click "Start" (or the Windows logo button in Vista and Windows 7) and
select "Control Panel." Select "Classic View" in Vista if
not already displayed. Double click "Mouse."
You may also access "Mouse Properties" in Vista
and Windows 7 by clicking the Windows logo and typing "Mouse" in the
search box.
Press "Enter," then click "Mouse" when
the search is finished.
Select the "Hardware" tab.
Select the touchpad and click "Properties."
Click "Change Settings" if the settings aren't
displayed.
Click the "Device Settings" tab in Windows 7 and
select the touchpad.
Click "Settings."
Click "Virtual Scrolling" in the touchpad
properties window.
Click the boxes next to each "Enable
Scrolling" box and click "OK." Scrolling is now turned on for
your touchpad.
Memory capacity
32 GB is the max ram you can put in that machine. If you are referring to storage space that is only limited to the amount of money you want to throw into it.
Reset computer
IF YOU MEAN TO ERASE,ALL DATA OF THE HDD'shttp://eraser.heidi.ie/ THIS PROGRAM DOES THAT.
One time boot
look in your bios settings there should be an option to enable this option.
Cd wont open
Take a large paper clip and open it.....there is a small hole below the tray usually on the right side. Push the end of the clip to manually open the drive.
The cd door won't open on the tower
CD Drive Tray problems There are two ways to open the CD drive door if the button just below the drive tray does not work. Go to My Computer and right click on the drive and click on Eject. If this does not work then you can manually open the CD drive tray by - Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc. If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
