20 Most Recent Blaupunkt Bahamas MP46 CD Player Questions & Answers
Thanks for the response, but this didnt work. Any
Bose systems were not created with aftermarket head units in mind. Normally people perform a Bose-ectomy on those systems, removing ALL Bose components meaning Speakers too. Personally I prefer Pioneer, JBL, or Alpine speakers.
10/18/2017 10:42:42 AM • Blaupunkt... • Answered on Oct 18, 2017
How to turn demo mode off on Blaupunkt MP46 ?
go to settings and then in display find demo and turn it off there.
6/11/2015 12:03:37 AM • Blaupunkt... • Answered on Jun 11, 2015
Can you give me the radio code for blaupunkt
post the other number beginning with 7xxxxxxxxx
5/23/2011 2:50:20 PM • Blaupunkt... • Answered on May 23, 2011
I have a balupunkt bahamas mp46 car cd stereo. i
You need to pull the unit out of the dash and pop the top and manually release the disc. If you don't have the keys for the side tabs (if it's not Iso-mounted) check a local car audio shop. They generally can be very helpful. Hope this helps. If your not sure how, post a comment with the make and model car and I can help you further.
4/17/2011 12:50:16 PM • Blaupunkt... • Answered on Apr 17, 2011
The volume is too loud......#1 is too loud to hold
Typically the left or right knob should adjust the volume by turning it counter-clockwise. However, some companies need to make this a bit more advanced or difficult. If this is the case, you can try pressing the audio button on the device. If it provides you with any options on the screen, search for anything which indicates changing the volume control. (It may also be under Menu)
Once you do that you should be able to turn the sound down with either the knob on the left or the arrows on the right.
2/21/2011 4:20:31 AM • Blaupunkt... • Answered on Feb 21, 2011
Where can i get a manual for bahamas mp46
2/21/2011 3:54:46 AM • Blaupunkt... • Answered on Feb 21, 2011
In my cedia bahmas mp46
Hello if you still want to solve this, This rquires removing the front panel. Thee are 2 screws inside the coin holder underneath the music panel. you wil be able to see them only if you bend down and see it. Remove them and the front centre panel will come out. then the screws that hold the music player will be visible. The you can remove them and slide th music unit out to fix your pod cable.
11/18/2010 3:26:27 AM • Blaupunkt... • Answered on Nov 18, 2010
I need a wiring harness for this radio. Can't seem
try Crutchfiled.com
6/13/2010 9:39:07 PM • Blaupunkt... • Answered on Jun 13, 2010
Harness available for hooking up blaupunkt bahamas
Hi, look for any RCA connectors on the wiring harness or rear of radio - these are the line output connectors - If there are no such connectors then your radio has no support.
Most amps will support hi level input but your sound quality may suffer a little bit because of the extra noise introduced by the stereo amp.
5/5/2010 2:11:02 PM • Blaupunkt... • Answered on May 05, 2010
Cant adjust sub out and midrange like i used too.
Hello chev_454,
You can adjust the sound settings for bass, middle, treble, and sub out separately for each source, tuner, CD, AUX, etc. The adjustment procedure is on page 26 of the owners manual. If you do not have a manual, you can download a PDF copy here at Crutchfield. They show the Bahamas as a discontinued m,odel but the manual is still in their database.
Hope this helps.
6/2/2009 1:15:41 PM • Blaupunkt... • Answered on Jun 02, 2009
2answers
Need an unlock code for
I think this is an old Blaupunkt where the code cannot be calculated using the serial Number.
It will require specialist advice . Try asking here for free advice....CLICK HERE Mention FixYa
3/18/2024 2:42:39 AM • Blaupunkt Car... • Answered on Mar 18, 2024
Hi, I have a Holden Commodore VX with a Blaupunkt Radio and I have lost the Pin Code to unlock, what can I do?
If you have the serial number from the radio there are loads of websites where you can get a replacement code.
2/17/2024 4:59:17 PM • Blaupunkt Car... • Answered on Feb 17, 2024
3answers
Please code for Blaupunkt gmbh 815 7 640 203 360 vwz1z2d7630194
TRY THE MANUFACTURER WE DO NOT HAVE OR KNOW IT
1/4/2024 2:32:19 PM • Blaupunkt Car... • Answered on Jan 04, 2024
3answers
Hi thereI have a holden barina 2004 with a Blaupunkt 2020 radio.
Radio codes are unique to each vehicle and are typically provided by the vehicle manufacturer or the radio manufacturer. To obtain the code for your specific radio, you will need to contact a Holden dealership or a Blaupunkt authorized service center. They will be able to assist you in retrieving the correct radio code. You may need to provide proof of ownership and the serial number of the radio (which you've already provided as BP248554092649 No 92 094 577). Once you have the correct code, follow the instructions in your owner's manual to enter it and unlock your radio.
9/24/2023 8:12:44 AM • Blaupunkt Car... • Answered on Sep 24, 2023
Hi, my tv is displaying serial number on the screen on every source I have tried to factory reset my tv many times still the same.
You may have to contact Blaupunkt support: https://www.umc-uk.co.uk/Information/helplineinfo.html Contact Numbers UK Technical Support 0330 024 0801* ROI Technical Support 01443 3940 Usual open hours are: Monday - Friday: 08:30 until 18:00 Saturday: Closed Bank Holidays: Closed https://www.umc-uk.co.uk/instruction-manuals/Blaupunkt-Television_information.html https://www.manualslib.com/manual/2784183/Blaupunkt-40-138m-Gb-11b4-Fegpx-Uk.html
9/4/2023 1:42:35 AM • Blaupunkt Car... • Answered on Sep 04, 2023
Blaupunkt Bahamas MP46 CD Player Logo
Popular Tags
15 questions posted
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Blaupunkt Car Audio & Video
Most Popular Question
get manual bahamas mp46
  • Car Audio & Video
