Is it possible to get a virus in a radio/nav system? My radio freezes up frequently, then reboots itself after a few minutes and plays fine for a while and then does it again. I cannot enter an address in the GPS as the more times I enter something, the faster it freezes. Occasionally it will display a message saying that memory is full.
SOURCE: computer restarts itself
boot into safe mode. a lot of times safe mode will load itself w/o the virus doing any damage. boot into safe mode and do a scan with the avast anti-virus and then do a boot virus scan with avast as well.
SOURCE: My Nokia frequently displays the message that the memory is full
delete some data and den try
SOURCE: the gps navigation screen freezes when launched
Here is how to Fix the GPS
Go To Web. Click on Live Search. Say any business or service name, Target, Walmart, Pizza, Mcdonalds, etc. Click on one of the finds. When the address pops up, click on the little car icon. Then it takes you to GPS. From now on GPS works.
SOURCE: When turned on a purple
Unplug your receiver for two minutes. When the first screen pops up I think it says acquiring satellite info do the following.
With the remote press menu then go to settings then setup then reset
and press restart everything .
Just remember to reset your times and settings on the dvr.
It may not work right away, just keep trying, including unplugging the infernal machine!
SOURCE: Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
