SOURCE: i have a samsung ht-tx75 and it keeps shutting
Protection is very likely caused by an over heat condition, even with the fan working if the receiver is in a very enclosed place that warms up and is not ventilated it will cause the problem. The solution is to provide more ventilation so that the receiver can cool itself properly.
SOURCE: SYSTEM SHUTTING OFF
I had the same problem and of course my system is out of warranty. If you open the system up most likely you will see portions of a board near the fan burned up.
SOURCE: my dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
SOURCE: remote code for samsung ht-x810
go to samsungusa.com and look for a listing for codes, or you can go to the store and look at a universal remote package for the code
SOURCE: We bought a Samsung Soundbar x810 but the
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
