Expert
- Posted on Oct 25, 2013
Re: How do i uninstall knctr
Quickly and completely remove Knctr from your computer by downloading "Should I Remove It?", its 100% FREE
http://www.shouldiremoveit.com/download.aspx
This will remove Knctr from your computer.
Or, you can uninstall Knctr from your computer by using the Add/Remove Program feature in the Window's Control Panel.
- On the Start menu (for Windows 8, right-click the screen's bottom-left corner), click Control Panel, and then, underPrograms, do one of the following:
- Windows Vista/7/8: Click Uninstall a Program.
- Windows XP: Click Add or Remove Programs.
- When you find the program Knctr, click it, and then do one of the following:
- Windows Vista/7/8: Click Uninstall.
- Windows XP: Click the Remove or Change/Remove tab (to the right of the program).
- Follow the prompts. A progress bar shows you how long it will take to remove Knctr.
- If for some reason uninstallation fails, please install Microsoft's uninstall fixer utility which will help fix problems with programs that can't be uninstalled at support.microsoft.com.
Hopefully it works and solve your problem. Please rate, thank you. Sharing is caring. :)
