Frigidaire Dishwasher - Hot water is coming in but spray arm is not working. I have checked it for clogs and obstructions but still won't work.
When a dishwasher has been checked for obstructions in the sump area and the spray arms can spin easily (by hand) plus the spray arm holes are not blocked, you end up with either a broken impeller or a failing wash pump motor.
If you would like more details of have more questions, please post comment back here, OK?
Good Luck!
Hello friend, thank you for your post!
Your water valve or spray arm could be the reason no water is getting to the top of your dishwasher. Remove the spray arm and clean it out with warm water. Also check to make sure that nothing is obstructing the spray arm from releasing water onto the dishes. I hope this information is helpful. -Matt
Thank you so much. I have fiddled around and, unfortunately, am not mechanically inclined enough to get the dishwasher apart myself. Are these parts fixable (should I hire a repairman or buy a new dishwasher)? Thanks a million!
same problem
