When enter 12345 message pop up code error
SOURCE: I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
SOURCE: tried to restore factory settings on 6500 nokia
try this :
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
rate please !
SOURCE: when i enter 12345 as a security code in my mobile
if the 12345 is not working than you need to use data cable for restore setting
SOURCE: I forgot my Nokia phone
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
SOURCE: i have fogot my nokia 1650 security code.without
i want clear the the timer code of nokia 1650
