Kenmore 40" Self-Clean Freestanding Electric Range with Two Logo
D
Debbie Payne Posted on Oct 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you replace the interior oven light and what is the part number for the bulb. Model 790-9747
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Oct 17, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
466400
Points
5959
You can buy a 40 watt appliance bulb at almost any store that sells bulbs.
2answers
Why won't the interior light on my Smeg SUK92MFX5 oven turn off.
These smeg ovens have a door switch (switch is on panel just behind top of door ) of may have moved or door has not been put on properly
How do I change the internal lightbulb?
Your owner's manual should show how. No manual, try manualslib.com
My old sears microwave light bulb is in the upper front left hand with bulb top up and socket down but behind a screen. There are screws to remove the upper fan apparatus, which appears to make the side available to extract the bulb. Probably a very special bulb, so I would get one before going to that trouble. It might also be the switch that is bad rather than the bulb. That probably requires removing the outer surrounding cover.
How do I find the fuses for my Electrolux PCHV42P88 hood? One row of lights is out and it is not a bulb issue.
Good Morning James Formalyn, thanks for your post!
I see that a row of lights is out on your Electrolux hood and you are searching for a fuse. I was unable to locate any additional information for your hood. The model number you have provided is PCHV42P88. If you could check the model number I would be able to locate any additional information. I look forward to helping you. -Matt
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Replaced element on frigidaire oven and oven still not working
Good Afternoon Friend,
I understand you've recently replaced the elements on your Frigidaire oven and that it is still not working. May I have your model number please? The serial tag, which lists your model number, is normally located in the storage drawer, on the right side if you have a range. If you own a wall-oven please check the front of the oven, on the left side, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better determine what may be causing the issue at hand. Thank you! - Z
Why is my oven not heating up?
My guess is the heating element has gone. Get online and search your domestic appliance web sites quoting the make / model / serial number etc and see what element is needed. If you are capable of good DIY and know how to isolate the cooker then its not a big job to replace. I've googled your model and the elements are readily available. You don't say where you are but the elements are readily available in UK for between 20 and 30$. I had a similar problem with my double oven and found a suitable height table, covered in news paper, slid the oven out of the unit, changed the element, all done in under an hour. If yours is under worktop then slide onto a piece of board on blocks.
Maytag mgr7775wb is not regulating temp properly
Why is the oven temperature incorrect?
The oven temperature controlis usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
The oven sensor:works with the oven control board to regulate the oven temperature. If there is an oven temperature problem, this sensor might be defective. The sensor can be tested by using an ohm meter. As temperature rises, the resistance measurement also rises. The manufacturer of the oven sensor determines the correct resistance,Oven temperature problems can be caused by other things,but this is one of the common causes.
Beware on some models nowmost of these ovens they are electronic and they are integrated into the control itself
some different sensor ohm readings at room temp. approx 16 ohms at room temperature and at 350?F it is 29~33 ohms.
Read more:
http://www.justanswer.com/appliance/5xrsf-ge-xl44-gas-oven-oven-ignites-even-when-oven.html#ixzz3YdtiPcn8
The reason for my free advice is GOD is good!
I have a maytag gas stove model #MGR5775QDQ serial # 14863475CX the oven takes a long time to light and when it does it will not maintain a temp.
You have a bad ignitor to your oven. Part number you should replace is 12400035. This should fix this problem. Just because it glows does not mean it work correctly, it works off of the flow of electricity rather then the glow of the ignitor.
Ignitor How to test How to change ignitor
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
I HAVE A CORNING COUNTERANGE. I THNK WE BOUGHT IT AROUND 1973. IT HAS BEEN A WONDERFUL APPLIANCE ALL THESE YEARS....BUT NOW THE OVEN THERMOSTAT DOES NOT WORK PROPERLY. THE OVEN LIGHT TURNS OFF BUT THE OVEN...
YOUR ADVISE DID NOT POSE A SOLUTION TO MY PROBLEM. I THINK YOU SHOULD REFUND THE TWENTY DOLLAR FEE YOU CHARGED ME FOR LESS THAN FIVE MINUTES OF "CHAT". NEITHER OF THE WEB PAGES HAD ANY HELPFUL INFO. WHAT A RACKET YOU HAVE GOING!
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
