20 Most Recent Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop Questions & Answers
The clock runs on 110 volts and the oven at 220 volts. If the cook top is on, the issue is in the stove. Best left to a qualified technician.
If the cooktop is also not functioning, check the breaker.
Kenmore 30 in.... | Answered on Jun 19, 2014
Make sure the clock is not set to "auto" function or on "timer" mode. The oven will not start until the correct time has come up. If the clock is not working , this is likely to be the problem. See if there is a manual operation control or switch. You may have to get a new clock or arrange for the clock to be bypassed so the oven can work without it. Most electronic clocks can stop an oven from working if they fail.
how do I change the eye on my electric 2000 kenmore smooth top electric range
Kenmore 30 in.... | Answered on Apr 10, 2014
need details
Kenmore 30 in.... | Answered on Oct 27, 2012
it could be a switch, element or a short somewhere else
Kenmore 30 in.... | Answered on Jan 15, 2012
From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Kenmore 30 in.... | Answered on Mar 26, 2011
Check below steps:
(1) Is there any problem with the breaker? if no go to step 2.
(2) Check with voltmeter if the current is coming to the knob of the burner? if yes go to step 3.
(3) Check if the current is coming from the knob to the burner.
Kenmore 30 in.... | Answered on Feb 03, 2011
YOU HAVE A PROBLEM WITH THE SWITCH. CHECK WITH SEARS TO HAVE THE PART NUMBER..
Kenmore 30 in.... | Answered on Jan 17, 2011
We have a Sear's Repair Center here, and I'm thinking that if you go there and explain your problem, they may be able to bring up some assembly diagrams (which is what you need), and perhaps be able to advise you on the wiring hookup. Electrical diagrams can help, but are often too general, not allowing one to have to refer to the assembly diagrams.
That's your best bet- they're the guys that fix these machines, and they will be able to help, with a little luck.
Hope this helps, and good luck.
Kenmore 30 in.... | Answered on Nov 17, 2010
how do i change the burners on eletric cooktops
Kenmore 30 in.... | Answered on Oct 20, 2010
This is almost always caused by the switch being faulty. If you can access the control panel (with the appliance unplugged) you can swap the possibly bad switch with another and see if the burner works properly. If so you will need to replace that faulty switch.
Cheers
Kenmore 30 in.... | Answered on Oct 06, 2010
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore 30 in.... | Answered on Oct 01, 2010
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Kenmore 30 in.... | Answered on Sep 05, 2010
Thanks for writing to Fixya.com.
The hot surface light is turned on by an auxiliary switch across the plate. Sometimes the switch gets stuck in the closed position. It is also possible that the plate is not turning off. Feel the plate and check if it is at all warm. If not, then the auxiliary switch is stuck closed. To resolve the issue replace the limiter which is the rod you can see across the plate. Sometimes you can only get the complete plate with limiter which is a bit pricey.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Kenmore 30 in.... | Answered on Jun 09, 2010
Kenmore 30 in. 42701 / 42702 / 42709 Electric Cooktop Logo
Popular Tags
43 questions posted
Top Kenmore Cooktops Experts
jdthefixer
mcgsp
Level 1 Expert
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Cooktops
  • Kenmore Cooktops
Most Popular Question
removed red blk white wires from
  • Cooktops
