What HP product is this.
to
Chukwudozie Echetabi wants more answers to this question
hyjacking 2013 old posts.
tell first whats in your hand, what is it , name and model.
an old IQaq
EVER THINK to ask at HP.com
No, really.!
why not ask the authorities, on this product.
they too will ask you whats in your hand....
https://support.hp.com/us-en/search?q=SIM%20CARD&filter=-1
Be sure you inserted the SIM in the proper position.
SIM card are sensitive, worn out/cracked/scratched sim can spell trouble. Be sure you have a good sim. Try to test it first to another laptop or a cellphone.
Good luck
Tedmac
SOURCE: How to eject RS-MMC card from card reader slot in acer 4736 ?
Usually there is a spring latch: press the card deeper into the PC, and it will click out.
If it doesn't, the spring may not have engaged, or may be broken. To extract a stubborn memory card, it usually has two grooves on the top and bottom to allow extraction by hand using your fingernails. Some cards don't have the grooves though, and for those you can use a pair of tweezers, or use two strong sewing needles as "prybars" from the left and right side of the card simultaneously.
If it still doesn't work, something went really really wrong with the latch and you'd best send it to assistance. As an extreme resort ONLY, wet the short side of an unfolded paper clip with Loctite glue, and taking the utmost care not to touch ANYTHING but the short side of the memory card, stick it to the memory card's short side. The traction made available by half an inch of Loctite on a steel paper clip should be enough to tear the memory card apart, let alone extract it. But if you need that much force, chances are that you'll end up destroying the reader: that's why I suggest going to the assistance if things come to that.
SOURCE: SD card can't be detected by the computer
Did you install your memory card reader drivers?
If you didnt, install it and it will read your SD card.
The drivers should come with the CD that came with your laptop.
You can also purchase a usb SD card adapter, it is not costly.
SOURCE: I have SIM card slot
If you don't have the 3G card installed in your laptop, you won't have access to any cell network.
In that case, the sim slot is just a dummy slot.
SOURCE: i have the sim card
Is it not a sim card slot.
The slot you are mentioning sounds like a card reader, its used for SD memory cards which you would normally use in a camera.
Cheers
Myke
