This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If it is a fan assisted oven, then it is probably the oven element that has failed.
This is usually located at the rear of the inner oven compartment behind a removeable panel
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If the element was gone completely then the oven would not heat up at all. If the element blew while the oven was on then that would explain why it was warm. Elements cost between £20-£40, plus any labour costs. You can find this out when you contact the repair shop. Another thing to consider though is that it could be the thermostat, which controls the heat. These cost from around £25 upwards again you would need to confirm this with the repair shop. All in all I think you are looking between £50 - £80 to get it repaired.
