Planar Pt1503nt White 15" Serial Resistive Lcd Touchscreen Built In Speakers Logo
Amir Posted on Oct 04, 2013
Planar pt1503nt lcd white screen problem.what is solution? when i power on my lcd its disply white screen. what is problem? please tell me.
2answers
What is the part no for hisance 50k390pad tv T con board
TV Parts Universal TV Stands DLP Chips ShopJimmy can tell you where to locate the part number for that board. and how much for a new one.
2answers
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Diagram screen
Hello the Lcd is bad get t replaced
1helpful
I have a Planar 1910(Black) LCD from a friend. It first had a problem where it would show no display but the power LED would flash green to orange. I fixed the problem by reseting it. Now that the display...
It has white screen becuase it may not be getting the 5vdc from the logic board to the T-CON board or the board has blown fuse.
Please see http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Also look to see if power supply/logic bd had any bad caps also.
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
2answers
22" SOYO LCD widescreen monitor problem!
Try seting your dettings to 1024X768 and see if that solves your problem.
2answers
Samsung x820 display not working
plz open it by using scrudriver then u will find the disply
there is disply conector u have ho clean up that connector by using petrol
Power supply pings distributions planar d6015tm
The information comes on the same manual of the planar monitor d5015TM (see as medical monitor)
3answers
OSD Menu won't turn off
Known issue -- can get a replacement if still under warranty. The planar rma techs are really really nice.
Top Planar Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Planar Audio Player and Recorder Expert? Answer questions, earn points and help others
