Hi! there,
well,if you think the unit turns as well as the compressor is running,no blowing of air,blower and fans are coupled at this type, if you hear hamming of blower fan,the capacitor is not working or theres no supply source on starting circuit.check capacitor disconnecting it besure switch breaker is off ,check performance using multitester,on resistance attached test rod to the two terminal of capacitor and tester set to 100k,if tester pointer deflect,then reverse the polarity of tester if deflect and sudden the pointer going back to original position,capacitor is good.if not go back the capacitor is busted,if not deflect its also defective.replace capacitor,have a nice day
