Precor Error 27, Too Much Drive Motor Current
Probable Cause
1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
Precor Error Code 27
SOURCE: The quick start button does not do anything,
You would need to replace the keypad overlay on the console.
SOURCE: I have a Precor c956i
Removethe red "STOP" cover. The cover may pushes against a switch. If theswitch moves too far down and rests against the cover, it will be stuck in alock position causing the error message. To remove the red STOP cover, removethe few screws behind the console. When the front cover is off, turn it overand unscrew the two screws that hold the red stop cover. Then push the coverout through the FRONT. Do not attempt to lift it out by the end with the screwholes. It will not pull out that way. Test the machine before screwing thepanels back again. The message should no longer show STOP KEY. Test the visiblewhite small switch that you uncovered by removing the red flap. The messageshould stop when you press the switch. If theproblem still exists then open the console and check under the magnet holderfrom inside you may see rust ire broken cable there, if you find thisthen you may have to replace it. Hopethis will help you.AV
