If you do not want to cut or tap into the vehicle wiring, you should buy an aftermarket adapter harness and splice the wires from it and from your Panasonic CQ-C1100U together.
The Scosche part number for your Camry is TA02RB. Wiring harnesses are also made by Metra and others. Here's a link to the Scosche part:
I'm sorry, but wiring diagrams for specific car audio systems are not readily available to the public. These diagrams are usually confidential and used by authorized repair technicians only. If you need assistance with the wiring of your Panasonic CQ-C1100U car audio system, I would recommend reaching out to the manufacturer or an authorized repair service for support. They should be able to provide you with the information and guidance you need to properly install and wire your system. It's important to follow the manufacturer's instructions and any relevant safety guidelines to avoid damage to the system or potential harm to yourself or others.
FYI if you remove the factory unit it will disable the cars starter and or fuel pump. The radio is tied into the security system. You shoud be able to get the wiring color codes here:
red -Acc power yellow -12 memory power black -ground blue -amplifier remote blue/white -power antenna
SPEAKERS white left front + white/black left front - grey right front + grey/black right front - green left rear + green/black left rear purple right rear + purple/black right rear -
Yes, the Panasonic CQ-C1100U can be connected to a 2-channel amp. It has a single set of preamp outputs. I'm attaching an image of the connection shown in the Panasonic user manual. The appropriate connection is the one without the dashed line. The dashed line showing a 2nd set of outputs only applies to the 1110, 1120, and 1200 models.
Hope this helps. If it does, please rate as "FixYa". Thanks!
The wires for the two harnesses should be color coordinated or at least closely colored. The harness should have come with either a guide that says what is what or the wires themselves have little flags saying what they are. You can use this to match it up with CD Players wires by using the manual from the CD player to know which wire is what.
