Can a ceramic cooktop on a Kenmore Electric Range Model #790 be repaired? It is not broken, but has melted indentations in 3 places from leaving a tea kettle burning. I already posted this problem, but somehow it is listed as a Jenair cooktop which it isn't. So this is a correction to my previous posting. Thanks.
SOURCE: manual for kenmore electric range
I finally found a website where I could order the manual.
Thank you.
SOURCE: Kenmore electric Range 2005
No! I haven't found a solution to this problem yet. The range still gives the F-30 error every time we attempt to program the oven. It has done this since the power failure accompanying hurricane Ike that blew through here in September.
I am still searcing for the reason for the F-30 code for free or very low charge. It is not worth $15 for the info alone. Once I find out what is causing the F-30 code, I will contact you again concerning the repair. In the meantime, the top burners still work, We are using them for now.
I would be much more inclined to use your repair services if you did not charge so much up front for mere informational troubleshooting.
SOURCE: my kenmore electric range model 790 is displaying
Frigidaire stove
(F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should
damage be extensive.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I need a new baking element for my Kenmore
Hi you can go to this site and get the exact part you need:
(You will need you entire model number) i.e 110.xxx xxx
http://www.searspartsdirect.com/partsdirect/merchandiser/browseSubCategories.pd?sK=5017&pSK=1935&description=Cooking
Ther is a red + sign on the page that says find the right part. Click that and enter your model number. Then the diagrams for your range will appear.
Thanks for using FixYa!
Kelly
To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
