SOURCE: Defrost hose plugs
Remove the back cover to access the top of that drain line. Take some table salt in a tablespoon and dump in the tube. Will drain so fast you won't believe it. Might have a big build up of ice blocking the top so get your hair dryer and defrost that big build up. Flush with small amount of water and monitor the drain pan located under neath the freezer. hope this was helpfull
SOURCE: Need a defrost timer for Arctic Air F22CW freezer,
You can get the timer on the link below.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-F22CW-%3d%3db193i890598&PartID=890598
Good Luck and please rate 4 thumbs up for the free answer
Testimonial: "Great advice"
SOURCE: I have a Artic Air
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.----------------
If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual
defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice collected
on the coils and in the freezer section will get melted. Clean the
water from the sections. Then Connect the power cord of the unit to main power
outlet after 24 hours/.Then set the temperature to normal in both fridge and
freezer section. It will take near to 4 hours to get run in its proper cooling
cycle. Then check, if the problem returns again. Then its defrost board problem. -------------------------
BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------
So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get
required parts from from online sites like:
--- www.repairclinic.com or from searspartsdirect online site. --------- This
should help.Thanks.Helpmech.
