SOURCE: panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
SOURCE: Can't use VCR
There's nothing wrong with your VCR. Your remote probably set to control your TV. To fix that, simply press the VCR button on the remote, and you should be fine. The "T-U" really means "TV," but the designers at Panasonic wanted to use the standard seven-segment display to cut costs, hence "T-U" instead of "TV."
