20 Most Recent
Panasonic PV-V4021 S-VHS VCR Questions & Answers
NO PRENDE NECESITO ELMANUSL DE SEVICIO TECNICO
Su manual puede ser encontrado en
http: // www2.panasonic.com/consumer-electronics/support/Video/VCRs/VCRs/model. PV-VS4821
Esto es un manual pdf entonces usted tendrá que descargar al lector de adobe en http: // adobe.com telecargas si usted no lo tiene ya.
12/31/2010 4:02:22 AM •
Panasonic...
Answered
on Dec 31, 2010
We just purchased a Panasonic VCR/TV Universal
The problem with universal remotes is that unless you enter the correct code for that model not all functions will operate. You need to try every Panasonic code in the code book, untill you find one that works the guide function. Otherwise the only real solution is to get the original remote.
8/24/2010 12:49:19 PM •
Panasonic...
Answered
on Aug 24, 2010
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
5/11/2009 8:12:47 PM •
Panasonic...
Answered
on May 11, 2009
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
9/28/2008 6:02:02 AM •
Panasonic...
Answered
on Sep 28, 2008
Panasonic VCR PV-4652
If the MFD (Multi Function Flourescent Display is not working, check the -27 - 30 Volt (minus 27V to minus 30V) supply line. The fuse or a fuse resistor (around .5ohms 1/8W ) will be blown.
Also, it is possible that the 3V AC heater supply line is disconnected at some point.
Check that also.
7/20/2008 7:12:09 AM •
Panasonic...
Answered
on Jul 20, 2008
Toshiba M-782
If pictures are rolling during normal playback, just check one thing first. Open the Cassette flap and see the condition of the tape. Is it chewed and stretched at the bottom? If yes, the problem is a worn Capstan / Pinch roller in the VCR. It is cheweing up the lower edge of the tape, and therefore the VCR is not able to process the 'Control Track.
All you need to do is replace the Capstan / Pinch roller.It is a big (approximately 1 inch high by 1/2 inch wide Black Rubber roller inside the VCR. REPLACE. Problem will be solved.
7/20/2008 7:09:01 AM •
Panasonic...
Answered
on Jul 20, 2008
Picture is jittery and voice is garbled with noise in background
I had the same problem recently with a Panasonic PV - V4521 which has worked for years for me. I tried everything including cleaning the heads with Q-Tips and pure alcohol. Nothing improved. I tried tape head cleaners. Nothing. So finally one day, as I was unscrewing the cables, this VCR fell down onto the bottom of my foot and drew blood. Now remember, I had been trying to fix this thing for at least 10 days.
So, I dragged it up and pounded the top of the VCR until the top caved in. Then, I opened my front door and tossed it so hard against the floor of my patio that pieces went flying everywhere. I gathered up the pieces and the twisted VCR, put it in a box, and tosses it real hard into the dumpster. It's fixed. I have no more problem with it.
7/4/2008 1:02:59 PM •
Panasonic...
Answered
on Jul 04, 2008
Fisher vhs
Sorry, you need the remote. There are sites that sell remotes.
Try partstore.com
1/2/2008 4:47:44 AM •
Panasonic...
Answered
on Jan 02, 2008
Panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
9/26/2007 4:51:49 AM •
Panasonic...
Answered
on Sep 26, 2007
Guide Rollers Won't Engage
hi
sorry
cant help tou more then before
it cant be solved in remote
look for torn straps
broken wheels
look from where the noise is coming from
it will give you a hint whats the problem
DONT KNOW?
take it to a technician
good luck
2/26/2006 1:53:08 PM •
Panasonic...
Answered
on Feb 26, 2006
Cassette loading process won't complete
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation.
If you're NOT still under warrantee you should at least open the VCR and Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced.
With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see:
1. The video head drum begins to spin.
2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks.
3. The pinch roller moves into position and presses the tape against the capstan.
4. The tape begins to move and is wound up by the takeup reel.
5. The picture and sound appear on the TV.
With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted.
This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head.
With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.)
Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette.
In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY.
12/30/2005 2:49:07 PM •
Panasonic...
Answered
on Dec 30, 2005
