Texas Instruments TI-86 Calculator Logo
Kady Le Posted on Sep 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you make a residual plot? And I don't mean finding the residual line and plotting it in a regular scatter plot. I'm talking about a residual plot with a horizontal regression line at zero and the scatter variables being above or below it.
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Sep 23, 2013
k24674
Level 3:
Answers
8093
Questions
0
Helped
4675801
Points
21596
The simplest way would be to create a table where each x-value has a y-value that is the residual at the corresponding x. With a 2-list data set you can plot you residual plot.
1 Related Answer
Anonymous
  • 10 Answers
  • Posted on Nov 12, 2009
SOURCE: steps from manual on how to do stemp plot box
To make a plot, first you will need to define a list. To do this, press "{", then enter the values of your list, separating each value with a comma, and ending the list with "}" then store (STO>) the list into a list variable ("2nd" + "1", "2", etc.). For a box plot, you will need only one list, and for a scatter plot, you will need two. One for the independent variable, and one for the response variable; that is, one for the X and Y axis, respectively. To make your plot, open the plot menu ("2nd" + "Y=") and select a plot. From there, you may select the type of plot and which lists to use as values.
To find the residuals for the line of best fit, from the home screen, press "STAT", then move one right to "CALC", then select option 4, "LinReg(ax+b)". Once this command is on your home screen, follow it with your X and Y axis lists, separated by a comma, eg: "LinReg(ax+b) L1, L2". Press enter. In a moment, you will be provided with 'a' and 'b' values. Plug those residuals into your "Y=" menu in the form "ax+b", replacing 'a' and 'b' with the residuals, and the line of best fit will be drawn across your graph.
I can't see all of plotted points in scatter plot
Try to set the Zoom window to ZoomStat, this way the scatter plot will display all statistical points in the data set.
Why can't i see the plotted points when i try to graph my L1 in a scatter-plot?
You cannot have a scatter plot with just one variable. You need values in L1 and values in L2. If you have only one set of values you can do 1-var statistics and plot a histogram (x-value vs. frequency).
I am entering information from a sample question for drawing a scatterplot and finding the linear regression equation. I have copied the example exactly and keep coming up with the same two problems. 1. I...
You might not see the scatter plot when you go to the graph because the boundaries are not set correctly. With the scatter plot turned on, go to "zoom" and then scroll down to "zoomStat" and hit enter. Try going to the graph again and see if the the scatter plot shows up. As for the the equation being slightly different than the examples, this is probably just the calculator rounding up the answers it gets. Good luck!
Create a scatter plot of the data
The drawing of the scatter plot proper is explained in the last part (Part F). You might want to jump right to it.
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. TO CLEAR OLD DATA
  1. Press [2nd][+] (MEM) to open the memory management screen.
  2. Press [4:ClrAllLists]
  3. The command echoes on main screen, press [ENTER] to run it.
  4. Calculator displays Done.
B. RUN the SETUP EDITOR Command
  1. Press [STAT][5:SetUpEditor] [ENTER] ; calculator displays Done.
C. TURN DIAGNOSTICSON option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DIAGNOSTICSON option. To access the command
  1. You press [2nd] [0] (CATALOG)
  2. While the list of commands is displayed, press [X^-1] (D)
  3. Cursor jumps to first command that starts with D, dayOfWk(
  4. Press the DownArrow 9 times to reach DIAGNOSTICSON
  5. Select it and press [ENTER]
  6. Command echoes on main calculator screen with blinking cursor
  7. Press [ENTER] to set the option
  8. Calculator displays Done.
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. ENTER THE DATA
Press [STAT][1:Edit]
Type in your D (X ) values in L1 and the N (Y) values in L2 (see picture 1). Sorry the picture does not have YOUR values.
TO OBTAIN statistical RESULTS (optional)
  1. After you finish entering the data, press [2nd][Quit] to exit StatEditor.
  2. Press [STAT] and highlight Menu (CALC)
  3. In the list select [2:2-Var Stats]
  4. Command echoes on main screen.
  5. Press [ENTER] to calculate the stats
Here is what you get (THESE~ARE NOT YOUR RESULTS). Your results will be different.
Notice the Down Arrow next to n=7. That means the results screen has more values. Press the Down Arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the statistics.
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have To perform a regression analysis.
E. PERFORM A REGRESSION ANALYSIS
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. Select Regression model (Example Exponential, linear, sine, quadratic, etc.) Here I selected Exponential
  1. Press [STAT] , highlight [CALC]
  2. In the list of regression models select [0:ExpReg]
  3. The command ExpReg echoes on main calculator screen.
  4. If you press [ENTER] you will get your equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
  5. While ExpReg command is still in command line, press the [VARS] key.
  6. Highlight the [Y-VARS] menu and select [1:Function], then press [ENTER].
  7. In the Y function variable list select [1:Y1]
  8. At the command line, you have ExpReg Y1.
  9. Press [ENTER] to save the equation of best fit in Y1.
Here are your results. (These are your actual results)
You also have r and its square.
Since the equation is saved in the Y1 function it can be superposed on the scatter plot. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
F. DRAWING THE SCATTER PLOT AND BEST FIT CURVE ON SAME SCREEN
Regardless of the curve of best fit, you can draw a scatter plot as follows.
  1. Press [2nd][Y=] (STATPLOT)
  2. Select [1:Plot1...Off] and press ENTER to open plot1 configuration screen
  3. Use arrow to highlight On and press ENTER
  4. Use the Down Arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOTE: To navigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the XLIST is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearance of the raw data point.
And here are your two graphs: the raw data scatter plot and the line of best fit on the same screen. On the picture the ZoomStat option was used.
Now, it is up to you to accept this model or to try another model.
Err:invalid dim while trying to make a scatter plot
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
2answers
How do I create a scatter plot?
D. ENTER THE DATA
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. Select Regression model (Exeample Esponential, linear, sine, quadratic, etc.) Here I selected Exponential
  4. If you press [ENTER] you will get you equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
Comments: Apr 19, 2010 - I tried to edit the post to address your particular need but after several crashes I decided to paste it as is.
The particular parts that are of concern to you are Part E (performing a regression analysis) and the following one where the best fit and the dcatter plot are superposed on the same display.
As you have guessed you must select QuadReg.
Hi, I can edit my table information in my calculator but am not able to graph from it and when i go to table it shows nothing.. what do i do?
From what I understand you want to draw statistical graphs (scatter plot, box plot, etc.) If you do not see anything it may be due to the fact that the statistical plots are turned off.
Type in the data in lists L1 and L2, etc. Press [2nd][QUIT]
Press [2nd][Y=] (STAT PLOT] . Select [4:PlotsOff] [ENTER] .
Screen displays Done
Press [2nd][Y=] (STAT PLOT] . Select [1:Plot1 Off].
  1. The configuration screen for Plot1 opens with the cursor blinking ON.
  2. Press [ENTER] to turn Plot1 ON.
  3. Use Down Arrow to move cursor to second line Type:
  4. Select the type of statistical plot. Use the right arrow to move highlight on one of the 6 types.
  5. Select the type:scatter, Xline, histogram, box plot, and press [ENTER] to validate the choisce.
  6. Use down arrow to select the Xlist: use [2nd][1] to choose L1, etc. and press [ENTER]
  7. Select the Y-List (L2) and validate by pressing [ENTER]
  8. Select the data-point mark.
  9. Press [GRAPH].
If you do not see the graph or if it is not well centred, press [ZOOM][9:ZoomStat] to restrict the screen to the data entered.
Hope it helps.
Thank you for rating the solution.
1helpful
Graphing problems
From what I understand you want to draw statistical graphs (scatter plot, box plot, etc.) and you window is set up correctly. Usually, one must first see agraph and adjust the window, but no matter.
If you do not see anything it may be due to the fact thea the statistical plots are turned off.
  9. Press [GRAPH].
If you do not see the graph or if it is not well centered, press [ZOOM][9:ZoomStat] to restrict the screen to the data entered.
Hope it helps.
1helpful
Steps from manual on how to do stemp plot box
3helpful
When i try to graph a scatter plot on my ti-83 plus it says ERR:INVALID DIM or it gives me a blank graph, how do i graph it?
Your stat plots are on, and may not be filled out/ correctly filled out.
go to [Y=] and go up to the stat plots ([Plot 1], [Plot 2], [Plot 3] ) and turn off the ones that are "ON" ( highlighed black w/ white text.) and press [ENTER] on the ones that are on and the problem is no more.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
