Coleman Mach III Air Conditioner Logo
michelle Posted on Aug 08, 2017
We have a tioga, the furnace would kick on but not always blow hot air. We took it in for service to replace what we thought was going to be sail switch and they replaced the thermostat. We picked up only to find our fuses blown and now our computer board is blown and the generator wont run. im guessing they shorted somethnign when they changed the thermostat but they say not possible please help.
5 Related Answers
Anonymous
  • 462 Answers
  • Posted on Mar 27, 2009
SOURCE: thermostat
Several things cause fuses to go. But you ace in the hole is that it works for sometime before it goes out. This suggests that a relay or contactor is not pulling in as it should. I would try replacing the fan relay (if so equipped) and definitely the compressor contactor. If either of these try to pull in and are off center internally the result can be blown fuses intermittently.
DO NOT GO ABOVE 5 amp fuse or you may burn out the transformer.
The other things that can cause a blown fuse intermittently where your describing (although less likely unless subject to rodents and or high or low voltage spikes)
1 a temporary short in the control wiring (wire to or from the thermostat).
2 A short intermittent on the control board (if so equipped)
3 A relay on the control board or the SS circuitry is not operating with in design parameters.
I would really like to know what you discover the problem is.
If this helped you understand your system or problem please rate me as high as you can and thank you for using fix ya. Good Luck.
Dan Favata
  • 233 Answers
  • Posted on Jul 12, 2009
SOURCE: air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Anonymous
  • 1420 Answers
  • Posted on Feb 09, 2010
SOURCE: thermostat keeps blowing fuses
There is a short in one of the thermostat wires. The fuse is triggered on the low voltage side of the unit. Replace the wires.
Testimonial: "Thanks for the info ,I will try this"
Anonymous
  • 10515 Answers
  • Posted on Sep 19, 2010
SOURCE: Our inside unit Coleman EB20B (outside unit
Mark all your wires using tape or by writing it down to ensure you will be able to hook them back up exactly the way you found them. Remove all the wires from your board again. Tape off the ends so you don't "short" anything together. Identify the wires going to your outdoor unit and the wires going to your thermostat. Hook the wires up one at a time starting the with C wires and the R wires. Then hook up G. Then W. Then O. Then Y.....and any other wires you might have. Check the fuse everytime you hook up one of the wires. Remember to do the tstat and outdoor unit wires one-at-a-time also..........meaning........you will have 2 "Y" wires. Hook up only one, then check the fuse, then hook up the other, check the fuse...........Eventually, that fuse will blow again when you hook up the right wire. Then you will be able to determine the color wire and whether it is the one for the tstat or the outdoor unit. Once that is determined, disconnect that wire at the other end and re-install the fuse and restore power. If the fuse blows, the problem is in your wire. If it does not blow, it is most likely a bad control coil. More often than not, it's the wire. Look for damaged insulation and "crimps". Usually the repair can be made with simple electrical tape and/or cutting the bad spot out, using a wire nut and electrical tape, and testing it again.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Anonymous
  • 1515 Answers
  • Posted on Dec 01, 2011
SOURCE: coleman mach furnace wont stay running. i turn the thermostat down until i hear it click, then i turn it back up to get the furnace to kick on.works sometimes and sometimes not. blower will always kic
Hi, I don't know if you are still having a problem, but it sound like the flame sensor on the unit is dirty and need to be cleaned. If it has a automatic pilot, it will have a flame sensor. Its made of porcelin with a metal rod coming out the end, laying next to the pilot flame. Just 1 screw holds it in place. Remove it and clean the tip with steel wool or a piece of sanding cloth. If you don't have this set up, I would need more info on the unit, model and serial number. You may also have a faulty thermostat, but I do believe it is a flame sensor.
Shastalaker7
2answers
Need help diagnosing Coleman DGAA077BDTD 'firing' issue.
It is a gas furnace and they need regular servicing, ideally yearly. Servicing can only be done by a qualified gas contractor. Leave it to the experts even though your diagnosis is probably correct.
https://www.winstelcontrols.com/itemdetail/COLDGAA077BDTD
My Amanda furnace blows hot air then shuts heat off then a/c kicks on
Does it have one of those thermostats that switch AUTOMATICALLY from heat to cool? Might be programmed to kick on at too close a temp. don-ohio
Furnace will not kick on. air will not kick on
check thermostat setting. make sure unit is on! when u say "air will not kick on"? are you saying the heated air is not blowing out? if no hot air, there is no heat to blow out! fix furnace!
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
House heater does not blow hot all the time. the furnace kicks on and then shuts of and then the blower just blows cold air. the furnace tries to kick on three times but shuts off, sometimes it works just...
When it blows cold air, there should be an error code blinking on the LED light located on the PC board. Look through a small viewing port in the front panel, then remove the front panel and on the reverse side there should be a diagnostic code chart to help you figure what is wrong.
3answers
Furnace is not blowing hot air. sometimes the gas
depending on age, it is probably the thermocouple, or the flame sensor that is dirty.
Top Coleman Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
