I've bought the headset last December, but since I've been travelling around a bit, I haven't been able to take it out of the box til this Sept!!! It flickers a blue light once when I plug the charger, but then it does nothing. No lights, nothing at all. Please help me! I've tried keeping it plugged for a day, but to no avail.
You have to get your battery changed!!
I found that if I removed the ear pad on the charging side of the earphones, and accessed the circuit board, that the connection from the battery to the plug was lose. I plugged the charger into the headphones, while I attempted to make the connection more secure or tight. When the red light came on and stayed on I put everything back together. Whala! The unit started to take a charge and has worked ever since. This maybe a common problem for this unit.
Change the chargeable battery inside..dunno if it's available in ebay..google it up...90% this is the solution..or else it is the voltage transistor that is defective.
I just purchased one and im having the same issue. How can I get it to work? Am I doing something wrong?
Same problem BT500 Is there an answer besides sending it back?
i have exacly the same problam as you sum1 help !
I have the same problem - Has any one got a solution?
I bought mine yesterday and am having the same problem. I plugged in in, light came on, then faded slowly out. Kept it plugged in, but it's still not charged. Any solutions?
Having the same problem, headset will not charge.
Bought two different head sets (h670) statrs charging in red then fades out with no charge.
My headset don't charging !!!
motorola H670 bluetooth wireless headset not charging either. Starts off with red light that begins flickering and goes off w/in 7 seconds after plugging it to the charger.
when i first plugged it in to charge, it flickers a purple light for a brief moment and then stops. is it still charging when the purple light is not on?
Mine is not charging. I tried to charge for one day, still no hope.
same model, not very old. Yellow charging light goes on, but no dial tone heard on earpiece. I don't think its really charging
Plug ..Motorola H670 it into charger. Within a few seconds red light flickers and goes out. Never charges
I put the headset in the charger it turns red then blue I take it out press the on button no lights what so ever - I have left it on the charger for weeks
