Cars & Trucks Logo
Posted on Apr 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Steering wheel is vibrating and shaking - Taurus Ford Cars & Trucks
Gary Loney
Level 2:
  • Expert 122 Answers
  • Posted on Apr 16, 2009
Gary Loney
Expert
Level 2:
Answers
122
Questions
Helped
47678
Points
378
It would be one of two things.....most commonly, there is a busted belt in one of the tires. Hitting a chuck hole pretty hard will cause this, or a curb.....the other would be that one of the balance weights is gone, causing the tire to be out of balance.....
3answers
Why does my car shake while driving past 25v 30 mph
What year is your car, maybe the steering is out of alignment or the wheels are out of alignment or they are unbalanced have you hit a pothole lately you may have bent your rim.
How do you know if a bad alternator is the cause of steering wheel shaking in a 2005 Chrysler Pacigica with only 149k miles?
Very unlikely a bad alternator is going to cause a steering wheel shake even if the alternator is seriously out of balance. In that case a high frequency vibration will run through almost the entire car and the alternator will soon self-destruct.
There are a few reasons why a steering wheel might shake and mostly these relate to the integrity of the front wheels and tyres, the roundness, the radial and axial run-out, the balance and the compatibility with each other and the vehicle. Problems with the wheels and tyres can further be aggravated by steering/suspension wear or misalignment, worn shock absorbers and even binding brakes or warped brake discs.
The rear wheels and tyres and suspension and brakes are also important for a smooth ride and could conceivably cause a steering wheel shake, though a different sort of shake to that caused by the fronts. In this case the vibration is often felt mostly through the seat of the pants and from the seat back.
Vibration at 70 MPH.
Warped or out-of balance brake rotor? Also keep in mind that loose rear differential trailing arms that allow the rear differential to squirm around can also cause steering wheel shake.
1helpful
Vibration in Cab of Truck
sounds like a bent wheel rim
Steering wheel vibrates when excellerate
if you let off the gas and it stops vibrating, have the cv axles checked. if the steering wheel shakes at parking lot speeds, a tire is bad.
Front wheels and steering wheel shake while driving
If you get a bad vibration in your steering wheel at low speeds without braking it is either a bad tire or a bad rim. If you get a vibration at speeds around 45-50+ and goes away you probably have a balance issue. If the vibration only occurs while braking then your rotors are warped. If low speeds it shakes i'd take it to a shop to check your tires.
1helpful
Steering wheel shakes and brakes vibrate badly when stoping
Sounds like the rotors are warped,Take to a brake shop and have them checked or replaced.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
