I have a dead seagate 500gig hdd, it has a sd15 firmware they say that sd15 firmware have a firmware bug, the solution of it is that, i have to update my hdd firmware, i have the latest firmware that is said to be good but i cannot update my hdd firmware because it is dead, the bios cannot recognize it, it just like stop or hang when it comes in detecting my HDD, when i disconnect my HDD the bios work fine, and i think my hdd motor spin because it have som vibration but not that strong.
what should I do to be able to update the firmware of my HDD.
and one thing, i read one of a story in the web, his HDD is dead and he has a important file on his hdd, so he try some trick in the net like freezing the hdd and some stuf... but it didnt work, so he try the swapping of the logical board, 1st he buy a same hdd he swap the board but it didnt work, later he found out that the firmware is not te same, so he search again, then he found a hdd whit the same model & firmware and when he swap the board it work... if i swap the board of good & the same model hdd but latest firmware version of sd1a,can it do the trick, can it work? because my hdd firmware is sd15.
You need to access the drive controller and reset it using an RS232 to CMOS convertor and hyperterminal. The problem is caused by the firmware on the controller software going into an infinite loop.
If bios is not seeing it then none of the software tools available will allow access.
Once the hard drive is reset, the disk is fully useable again. A firmware upgrade is possible at this point, but usually we just image the disk and load it onto a more reliable replacement as most customers do not want to experience that sort of fright again.
I have fixed a few of these and have the equipment to do it, but it is not really a task for the amateur.
Hi y'all!
I had my 500Gb drive fail just before Easter. After a lot of research on the internet and inquiries to companies for a quote on data-recovery, I decided to give it a shot myself.
Fortunately I have more than one 7200.11 SD15 hard-drive and one was still working.
Here's how I did:
I emptied the functioning drive.
I switched the controllers between the drives and connected the good drive with the bad controller to my motherboard.
The BIOS found it. There was some stuttering noise going on from the drive, but I had nothing to loose.
I had made a CD with the firmware update to SD1A from Seagate.
Once I knew that BIOS found the drive, I disconnected all other drives and booted from the CD. The firmware was updated.
The drive was still not found by Windows (7 ultimate 64), but I was interested in the data from the other one, so I switched back the controllers between the discs and booted again.
The BIOS found my "crashed" drive with the newly updated controller.
Started Windows again and... There it was with all the data intact!
At the time of writing this, I still haven't checked if the other drive, that I used to do the fix, is still working, but... it had been emptied before the whole experiment.
So, there is light at the end of the tunnel if your drive disappears due to the firmware error. If it still hasn't failed, I recommend you to update the firmware to SD1A as soon as possible.
Have fun!
[email protected]
As all the 7200.11's fw has the bug,so if you cannot update it,then maybe you can go to ask the ST official about this problem.
Aslo some tools can help you solve the 7200.11's problem,such as HD Doctor Tool from SalvationDATA.
Any problem you can ask me by my email:[email protected]
CALL ME FOR ALL UR NON DETECTING 500GB HARD DISK TO RECOVER ALL UR DATA AND REPAIR UR HARDDISK IN GOOD CONDITION ...
THANKS ...ENJOY
Chetan
call 9828224899, 9829081513
Hi guys!
I hit the same problem yesterday. The drive is ST3500320AS (Seagate 500 GB SATA with SD15 firmware).
I have some relevant data on that disk and it would mean a LOT if I could get it running, at least to copy that data.
I don't have the equipment to kickstart that drive controller.
What should I do?
Any help is very welcomed.
Regards,
Strsljen
Call Seagate technical support. The guys are really helpful and will send you a ups shipping code so you can mail in the dead hdd and they'll flash the bios for you and send it back. Hopefully this will nto affect your data.
Dave836, I am an amateur, so your explanation sounds good, but what am I supposed to do with it? You say you can fix it, but how can I get in touch with you so that you can fix mine (for compensation, of course).
Thanks,
I have my 500 GB Barracuda lying in the trash. Once the problem starts there's no way you can make it detectable....Then how are you going to update your firmware. The only solution.. Buy a new HD preferrably NOT from Seagate. There are millions of customer pissed with SD15 issue. But the GREAT Seagate has not taken any step to help you with Data recovery. Recovery firms will charge you Rs 40000 to 50000 which is 9-10 times your Seagate Barracuda.....
I have the same problem. My drive(Barracuda 7200.11) worked fine last night, shut my pc down went to bed. Woke up and tried to turn my pc on but it wouldnt boot. Went into bios and it appears that it cant even detect the drive. I just bought this drive 3 months ago. I will never buy a Seagate drive again.
