20 Most Recent Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Questions & Answers
if there is a massive recall then it is junk ans should be treated as such
replace it with a Kingston solid state unit for trouble free service
Seagate... | Answered on Feb 12, 2018
Hi Simlei.
If its a modern, fairly new drive, it should have built-in firmware, without a need for extra drivers.
If you OS is old the OS itself may not be recognizing the drive's 'language', especially if the bus-width differs, ie 16/32/64bit.
As 1 TB is quite recent on SSD's, I guess its new.
My 1 TB Toshiba just plugs into USB and Win Explorer detects it as a storage drive.
Regards, Clive.
Seagate... | Answered on Nov 23, 2017
Yes it will work with XP, I assume that is what you are asking.
Seagate... | Answered on Jan 07, 2017
They could be electronically and physically the same but I do not think the firmware is the same hence it will not work properly.
You need to contact Segate, that is proprietary information.
Check out Hirens Boot CD that has many hard drive apps to check your drive for errors:
http://www.hiren.info/pages/bootcd
Seagate... | Answered on Oct 15, 2013
It is perfectly safe to remove the power cable from a hard drive but leave the data cable connected. Make sure that whenever you want to connect or disconnect the power cable, your computer has been shut down first. You could do it with the computer powered on as well, but this would not be good practice and you may put errors on your drive.
Seagate... | Answered on Apr 25, 2013
READ THE MANUAL AT SEAGATE.
or look at the chips there, see those I/O chips
see the p/n on them. look them up and read the data sheets.
see the pata pins, see them , enter the PCB with copper traces
they land on the I/O chip, and is clearly labeled on all mine.
great question, I worked as and ATE test system programmer and we do this all the time. There are many tests. not just i/o.
Seagate... | Answered on Apr 07, 2013
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Seagate... | Answered on Feb 28, 2013
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Seagate... | Answered on Nov 20, 2012
Nope, even on swapping hard drive board with same spec(size, board version) doesn't guarantee success.
Consider how the hard drive is construct on different brand. Initialization, disc number and many things.
It maybe, if it is same spec like size, brand, board version and model batch.
Seagate... | Answered on Aug 28, 2012
Purchase or download a partition manager program.
The only way you can easily manage or change your partition size is to get a third-party program.
Partition Magic Freeware is the most widely known partition manager software. http://www.filehoo.com/download/Partition-Magic-8,0.aspx You can also download freeware programs such as Cute Partition Manager. http://download.cnet.com/cute-partition-manager/3000-2094_4-10605516.html
Open or run the partition manager.
In Partition Magic you can open the program easily. In Cute Partition Manager you may have to create a boot disk and boot from it to run the program. Once the program is open, select the drive you want to manage.
Go to the menu and choose an action or right-click and choose "resize." There will be an action -menu that will let you choose something like "resize" or "change hard drive size."
Some programs will also let you right-click on the graphical expression of a drive and choose the action or drag the graph to change the size.
Pick a new size for the drive and decide what you want to do with the remaining space. The rest of the space should be partitioned or formatted to make use of it if the current partition is downsized.
Apply the changes by clicking "apply" or "OK." You will then have to reboot the computer for the changes to take effect. The program may automatically do this for you or it simply may direct you to do it.
Seagate... | Answered on Aug 25, 2012
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
190 questions posted
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
BARRACUDA Seagate
  • BARRACUDA Seagate
Most Popular Question
amd fm2 motherboards
  • Computers & Internet
