Technics SL-BD22 Turntable Logo
Anonymous Posted on Aug 28, 2013
Crosley turntable on my record player is unbalanced does anyone know how to fix it
Scott Pruitt
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Mar 15, 2014
Scott Pruitt
Contributor
Level 1:
New Friend:
Answers
25
Questions
5
Helped
6991
Points
31
Sorry Regina but it sounds to me like you need to ditch the Crosley & step up to a SL 1200 model.
1helpful
I need the instructions for the Crosley Director 2405B Audio Turntable Deck.
CROSLEY DIRECTOR CR2405A INSTRUCTION MANUAL ...
https://www.manualslib.com > ... > Director CR2405A
View and Download Crosley Director CR2405A instruction manual online. Director CR2405A turntable pdf manual download.
Crosley Director CR2405C Instruction Manual (Page 2 of 48 ...
https://www.manualslib.com > ... > Instruction manual
View and Download Crosley Director CR2405C instruction manual online. Director CR2405C turntable pdf manual download.
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
1helpful
I got my crosley record player yesterday and I tried turning it on today and the knob doesn't click like it's supposed to. Consequently the power light doesn't turn red and the turntable doesn't spin....
Hi A Soni...word of advice...if this a new unit DO NOT attempt
to fix the problem yourself...you may void any warranty attached
to the product. Call Customer Support 1 866 Crosley.
Regards,
Dennis
How to fix a broken speaker on a crosley cr40 turntable?
If the voice coil to the speaker is damaged, you have to replace it with an other one.
Shaky sounding records
Some things to check:-
Is anything preventing the turntable from rotating smoothly, this would cause a judder.
Perhaps the records are sliding on the turntable, a rubber mat will cure this.
Ensure the record player is on a level surface.
Crosley Turntable Repeating little bits?
Is this on all records? if yes! you need to adjust the weight slightly, if the problem is with one record, clean the record in luke warm water and dry carefully, may solve the problem.
Hi there, We bought a Crosley CR66 three weeks ago - it's been working beautifully until now, when the turntable has suddenly become completely unbalanced, and now kind of 'undulates' rather than...
It sounds like the record platter is not seeded correctly onto the turntable body. Is it possible to reseed the platter?
The belt driving the unit could also be off center, causing your undulations.
Is the mat properly centered on the unit? would this be causing the undulations?
82helpful
3answers
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
