My skype has gone nuts. I didnt touch anything and one day I tried to call a friend and she couldnt hear me at all. a little skype msg popped up saying "your voice input is too low, skype can not hear you." I check the settings and everything it all seems fine. Can anyone help me? I would really appreciate it. :-)
Cheers,
Hi.
not sure if this link will help you out but have a look.
Skype keeps on saying that my voice input is too low Google Search
SOURCE: Mic isn't working in Skype
Your logitech will not fix your C-Media CM6501driver.
det60,
Does your sound function? Can you hear sound through speakers or headset?
You did the right thing by testing the mic in control panel, audio device. Lets look at one other place.
Open control panel than open system. Click the hardware tab & than click device manager button. Scroll down to Sound, video and game controller. Click the + sign. Do you see a yellow ! point? If you do see the yellow ! point than you need to reinstall your sound driver software. Or better yet download the latest audio driver for your board from Asus web site listed at the link posted here: http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
CMedia beta driver. Version: V5.12.8.1802
If there was no yellow ! point than your audio chip is defective.
Your audio & mic are intergrated into the board. The audio chip controlls both audio & mic. This is a very common break down for Asus boards, (made in China).
Your board was made in 2006 & it's warranted for three years.
You have two choices.
1. You can buy a PCI sound card & install that into your system.
You'll have to turn off the intergrated audio in the bios as well.
2. You will have to call Asus & talk with the tech dept.
812-282-2787 IL EST
A tech will ask you for the serial no# located on a white sticker on your pink printer port Lpt-1. The tech will have you re-run the test you preformed (setting up the mic). Than they will issue you a case no#.
Than you'll have to call CA, RMA dept. 510-739-3777
You give the RMA dept your case no#. They email you instructions. You pay to ship your board to Asus tech IL.
Than around 10 working days they'll ship (free) it back to you (replaced with another board), but working.
Same model no#, different serial no#.
(I so hate giving out bad news!)
The choice is your's.
Good luck & best wishes
Don't forget to vote please..
SOURCE: no sound with Skype and logitech webcam
You might find the Skype sound set-up guide useful :)
SOURCE: People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
SOURCE: My microphone won't work. I can't hear my voice.Toshiba Satellite
Check which microphone device u have set up. Try changing it around. Also try just speaking closer to the microphone and into the mic. Some mics just are not good.
SOURCE: skype sound test
This means you need to tweak the volume levels a little and maybe also change the recording levels.
Echo is a common thin with VOIP communications and it may not go away fully but tweaking your levels shoul minimise it.
Also do not use VOIP type communications on low speed connections
