Check there is battery voltage at the fuel pump terminals , if ok replace the pump , if no voltage go to pump relay and check voltage if ok make sure relay is working then check wiring back to pump, if no voltage at relay trace wire back to fuse. Note there will be voltage at the pump only for a short time before the ECU shuts it down if the engine does not start.
Probably a bad fuel pump. Verify power and ground arriving at the pump during cranking.
SOURCE: 1993 honda accord wont start on hot days after sitting for hours
THE BRAKE LAMP WAS ON THIS SATURDAY WHILE I WAS DRIVING.SO ON SUNDAY WHILE IT WAS RAINING I PARK IT UP BY MY HOUSE AND THEN WHEN I WAS COMING OUT SIDE TO START THE CAR WOULD NOT START KEEP ON TURNUNG BUT NO START FINDLY AFTER AFTER ABOUT 2 MIN IT DECIDE TO START BUT THE HOLD THIS THING IS WHEN THE CAR WAS IN THE HEAT AND SITING THERE IT START
SOURCE: Replacing Fuel Filter on 92 Accord LX Wagon???
Fuel filter (faceing Engine) is on the Left of the firewall below the black box with vac. lines going to it There is a bolt 10mm head at that box which will allow you to flip box without disconnecting vac.lines. Good Luck
SOURCE: i have a 91 honda accord lx starts fine runs good
It may be the O2 sensor. I know it's not the fuel filter, spark plugs, spark plug wires, Vehicle Speed Sensor, Dis. cap, or TCM.
SOURCE: 1994 hoda accord lx brakes
Please refer to the link below.
http://corp.advanceautoparts.com/english/youcan/asp/ccr/ccr20011001bb.asp
SOURCE: 1986 Accord - fuel pump relay problem - HELP!
relay is under dash on driver side behind cruise control box. You tube has a demonstration on there for 92 accord.
