1998 Honda Accord Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio wiring problem
Need to know the color codes for wiring on factory harness for stereo deck. thanks...........ron m. need factory color code diagram for stereo in 1983 toyota camry ive looked online but the diagrams ive found colors dont match up well, i cut the harness off i get different stereo, but the wires color not match so, i dont know wish one is for what.
Marvin
Level 3:
Top Expert:
  • Honda Master 85,242 Answers
  • Posted on Apr 06, 2009
Marvin
Honda Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29061159
Points
266281
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Wanting to know which wire and also which colour stripes goes were in 2004 Subaru Impreza car stereo please?
2answers
88 vette aftermarket head unit stereo wireing diagram
Might be able to get an adaptor that plugs straight in painlessly.
Failing that it's the standard trace and identify method that eats time like crazy.
1helpful
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
2helpful
Radio wire colors
1994 Volvo 940 Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): White
Right Front Speaker Positive Wire (+): Gray/White
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/Brown
Left Rear Speaker Negative Wire (-): Yellow/Green
Right Rear Speaker Positive Wire (+): Green/Brown
Right Rear Speaker Negative Wire (-): Green
Hope helps (remember rated this) TY for use Fixya.
I need to know the color codes for the radio rear sub.
2000 Ford Expedition Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Purple
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Size: 6′ x 8′
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Light Blue/Black
Right Rear Speaker Positive Wire (+): Purple/White
Right Rear Speaker Negative Wire (-): Light Blue
1helpful
2answers
I`M REPLACING THE ORIGINAL RADIO ON A 1996 GMC JIMMY, I NEED TO KNOW WICH WIRES ARE WICH, (ALL THE POWER ONES) OLD RADIO NOT AVAILABLE
PLEASE RATE MY SOLUTION, THANKS.
1996 GMC Truck Factory
Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
2helpful
2answers
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
4helpful
2answers
2002 Taurus stereo
Here are the factory wire colors, please rate this solution to your problem, a note any stereo store that sells auto decks has adapter wiring harnesses to do a direct plug in of your DIN standard radio you are trying to install, no cutting of the factory harness, they are cheap
2000 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Illumination Wire: N/A
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
41873213 here ya go JIMMY...............
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
