Arctic Cooling Arctic P311 Headphones Pink Logo
A
Anonymous Posted on Aug 07, 2013
Arctic headphone wont charge - Arctic Cooling Arctic P311 Headphones Pink
Marvin
Level 3:
Top Expert:
  • Arctic Cooling Master 85,242 Answers
  • Posted on Mar 15, 2019
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29061525
Points
266281
Simple, either the charger is defective or the battery has failed.
Why won't the display screen on my 2008 400 Arctic cat turn on and why will it not start from the green button?
Check the charge on the battery, should be at least 12.6 Volts DC, then look for loose or corroded connections, starting with the battery cables.
I got a bytech bluetooth headphones a few days ago and the battery died after a few hours and now I've been charge it for over 8 hours and it still wont turn on when I unplug it.
Take it apart carefully and remove the battery, then replace it with a slightly larger Li-ion battery.(The headphones are built with Li-polymer batteries,lightweight,but not very efficient)
2006 arctic cat 650 v2 atv won't charge.
Weak or dirty magneto.broken wire to charging system.
here are the service manuals for all Arctic cat ATVs
Here
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
Icandy bluetooth headphones wont turn on but it will charge help??
Sir i have a icandy freedom 180 headphones but i dont know how to charge them. It does not have any charging except for Aux port thanks. Kindly explain it with detail how to charge them thank you
6helpful
2answers
Red light wont go off headset wont turn on
SImply connect the headphones to a power source. Then press up and down volume buttons at the same time. It will reset the headphones.
2answers
Headphones wont turn on
battery is toast get a new one anything electronic if u do not upkeep the charging it will die qwik
Top Arctic Cooling Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an Arctic Cooling Audio Player and Recorder Expert? Answer questions, earn points and help others
