20 Most Recent
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Questions & Answers
Says it is paired, but
In your Audio section of your PC find "Sound" and select Bluetooth rather than your speakers, and then do not forget to change it back when done.
1/12/2017 7:53:34 AM •
Insignia...
Answered
on Jan 12, 2017
I can not my headset
1. There may be a switch on the headset. Please switch it on.
2. click Connect headset on the Bluetooth window
1/12/2017 7:52:49 AM •
Insignia...
Answered
on Jan 12, 2017
I need drivers for Insignia headphone wireless
Windows 7 should automatically find the device and install the necessary software when you plug in the "Insignia" bluetooth transmitter. Once this is complete (can take a few minutes) you will need to connect your headset. It will connect and attemp to install drivers. It will not find the drivers on Windows Update, but instead it will tell you that you need to download a "Lenovo" driver and go to the broadcom website. Ignore Broadcom as they have removed this from detected devices and will just lock the system up. Instead download the Lenovo "Bluetooth with Enhanced Data Rate Software" driver that it suggests even though you may not have an IBM/Lenovo system.
The filename it downloaded for me was "7zbv14ww.exe", but if you do a google search there is a v15 available but I haven't tried it as the v14 is working perfectly fine for me.
Hope this helps.
1/10/2017 7:38:20 AM •
Insignia...
Answered
on Jan 10, 2017
What is the pass key to my insignia bluetooth
bluetooth Passkey
By default all bluetooth devices come with a 0000 passskey must earpieces won't allow you to change it unless is a very high tech device.
try that remember 0000 is the code.
if it works for you don't forget to rate me
thx
1/10/2017 3:13:45 AM •
Insignia...
Answered
on Jan 10, 2017
How do i make it
You need a bluetooth adapter,
search for "bluetooth adapter for ipod" on Google or eBay, to see what's around.
1/10/2017 2:58:57 AM •
Insignia...
Answered
on Jan 10, 2017
Lost Disc
I bought this headset from Best Buy and it came with a usb dongle. I also lost the disc. Insignia's website is useless, and the Broadcomm update website is down at the time of this writing. After hours upon hours of scouring, I found a working driver, which works perfectly. This works on Windows XP, but I can't verify that it will work for Vista. I hope this helps you.
http://drivers.anycom.com/bluetooth/usb-200-250/anycom-bluetooth-usb200-250-windows-v5-1-0-4200.exe
I will never buy Insignia products again because of their lack of driver support.
Best regards,
RobotJay
12/26/2016 7:24:54 AM •
Insignia...
Answered
on Dec 26, 2016
Headphones appear to be locked.
I had the same problem earlier. Try resetting the headset. Just plug it in to the charger, and press both volume buttons at the same time. It will turn off immediately. Wait a bit before turning it back on.
12/22/2016 8:09:28 AM •
Insignia...
Answered
on Dec 22, 2016
I can't find the pairing
the code on the PC side should be 4 zero's, there is no code to set on the headphones side of things, just power the headphones on and on the PC set to serch for new devices.
12/20/2016 8:22:46 AM •
Insignia...
Answered
on Dec 20, 2016
