Every time I pull the trigger my nailer fires but two nails come out. Sometimes they go all the way in and sometimes they stick out about 1/4".
First look at the end of the rod which pushes the nail. Is it bent or worn?
If not, look at the guide for the rod. Is it worn?
If both pieces above are good then the top or bottom of your jaws are worn out. You should replace both of them. The cost depends on your make and model. Some are cheap to replace, others get pricey.
