11 year old dryer, worked great whole time until recently. Shuts off early like it has over heated. You then can not turn it back on until 10- 20 minutes later. Faint smell of something burning. Clothes are o.k. in drawer just smell it. Maybe something caught in the pipe.
Don't know if this is the model, however it is a whirlpool super size electric dryer.
SOURCE: my whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
SOURCE: Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
SOURCE: Whirlpool LER7646JQO Electric Dryer turns on, drum
Most dryers have more than one thermostat.
Most likely, the operating thermostat has failed, but the high limit thermostat is working and turns off the machine when it gets too hot. When it cools down it will start again and run briefly. If the high limit thermostat fails, the thermal fuse will permanently stop the dryer to prevent a fire.
SOURCE: Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Dryer runs for 10-20 minutes then stops
