SOURCE: when activating bluetooth on dell inspiron 1525 it
download wireless 355 bluetooth module driver and install. it will install properly. you are using the wrong driver.
SOURCE: I can not turn off my Wi-Fi with using fn+f2. when
open your battery and insert it again then switch on your notebook and see
SOURCE: dell inspiron 6400 Vista : the wireless card turns off
is ur WIFI connected thru USB ?
then ur USB is losing power...
check if ur USB setting...
go to Device Manager/USB Serial Bus/USB root hub...
go to each ports one by one....right click on each check properties...check Power Mgt tab....
remove the Tick in the box that says "Allow computer to save power'....
close Device Manager/ Shutdown and restart....
SOURCE: how do i switch on the wifi in my dell inspiron
You can turn on/off Bluetooth and Wireless using the Fnand F2 key.
To enable or disable wireless networking, press <Fn><F2>.
Turns on when a card with Bluetooth® wireless
technology is enabled.
NOTE: The card with Bluetooth wireless technology is an optional feature, so the ordered the card with your computer. For more information,
see the documentation that came with your card.
To turn off only the Bluetooth wireless technology
functionality, right-click the
area and click Disable Bluetooth Radio.
To quickly enable or disable all wireless devices, press
<Fn><F2>.
Please refer the page #69 to 74 for complete information on the Wireless and Blue-tooth
http://support.dell.com/support/edocs/systems/ins6400/en/om/MD402AO3.pdf
SOURCE: problem in installing bluetooth driver in dell inspiron 1525
Switch on the Wireless Switch on the right hand side of the computer.
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
