Stove powers on all features work except burners and oven elements
Check you outlet make sure it has 240 volts coming out. it might be your house breaker 1 side bad it is a breaker with 2 points in it 1 side will work and give you 120 volts but the other side is burned out you need both points in contact to give you 240 volts good luck and make sure you use a volt tester you can buy at any hardware
burner control loosened the 2 screws but it won't come out
