Kodak I660 Flatbed Scanner Logo
Posted on Mar 30, 2009
Scanner Error Scanner not allowing items to be scanned instead an error is showing as E298+Calibration Required.
  • Anonymous Mar 12, 2012
    We buy, sell and trade; new, used and refurbished scanners. Call me about the Kodak i660. Andre 855-420-8273 ThirdWindTechnologies.com
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Mar 30, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
Helped
15254
Points
61
Some electronic equipment such as printers and scanners need to be "calibrated".
I recommend you follow the directions and allow the Scanner to calibrate. This may result in better scans and for printers, better printouts.
Sometimes when it is scanning the light moves really slow. It is almost like it is moving back and forth. It does this on small items and large items I am scanning. but not all the time
You might have to calibrate the scanner from time to time. The software included should have some type of calibration options. Without calibration, the scanner's "scanning capabilities" deteriorate over time.
THE UPPER UNIT FLASHES ON THE SCREEN WITH ERROR CODE 39,003,40;75554
On the Xerox 8560MFP multifunction, this error code 39,003 signifies a Scanner problem, specifically that the Optical Test has failed. the 75554 is your current page count on the printer.
The Scanner Assembly 062K22590 must be replaced. It is fairly expensive, but moderately easy to replace.
You should also order the Scanner Calibration Sheet 109K01910 to make sure that margins and contrast are correct.
The scan/ document section is broken into 2 main parts, the Scanner, and the Automatic Document feeder. The feeder section is probably working fine.
Good luck with that.
37helpful
11answers
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
1helpful
2answers
I am getting error code 843.01, what is the solution?
Found this information on the web. Hope it helps, because, Printer has been discontinued.
Problem
843 error; 843.01; 843.01 error; Scanner error; Scan error; Cannot scan; Will not scan Solution--Overview
An 843.01 error is generally caused by the Bottom ADF Cable on the scanner being loose or unplugged. Did the error return?
Yes: Continue to Contacting Lexmark
Items is Discontinue
2answers
CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
1helpful
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
3answers
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
1helpful
I280 won't scan!
ImageCalibration means the cameras don't get enough light during their self test.
Please check the following points:
Are both lamps on or one lamp in case you have a single page scanner?
Are the imaging guides (the clear sheets above the cameras) clean?
Are the little white tags on the imaging guides present?
One tag on each imaging guide.
Without this small white tags the cameras are not able to check themself.
For emergency you can apply a small white paper or white insulating tape instead of missing tags to test the scanner.
If the lamps are light, both tags are present please calibrate the scanner with the kodak calibration sheets. You will find the calibration menue in the scanner validation tool. You can get this tool from the Kodak home page.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
