20 Most Recent
Canon CanoScan LiDE 70 Flatbed Scanner Questions & Answers
Cannot communicate with scanner cable
Firstly you need to download the latest Canon MF Toolbox from the Canon website. .
Once downloaded, install the application.
Once installed, right click on the application icon and select
Move to the compatibility tab and select the checkbox behind "Run this program in compatibility mode for"
From the drop-down list, select "Windows 7"
Can the canoscan lide 70
Yes, but you have to use a special program called an "OCR" (Optical Character Recognizer) which will "read" the document from the scan. A scanner only produces a picture of a document, and it requries special software to "read" that image and make it editable.
The LIDE 70 comes with OMNIPAGE SE (special edition) which will work for simple documents. For more complex documents, you may need to buy the full edition of OMNIPAGE or another OCR package like FineReader. It is also built in fto software like OneNote and Evernote.
The top 5 free OCR tools are here:
http://www.makeuseof.com/tag/top-5-free-ocr-software-tools-to-convert-your-images-into-text-nb/
CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
Where is the power button
There is no power button on mine. It gets its power from the high speed usb so it is always ready. Every time I boot up my mac I hear the scanner go thru a warm up scan. I have downloaded the twain plugin for photoshop and access it that way. The lamp will go on when you preview scan something.
