2007 BMW 320i E90 Logo
Anonymous Posted on Jul 19, 2013
Cluster problem BMW e90 320i
Hi, im having a serious problem whith my Bmw E90 320i Limousine 2007 (Europe version). My cluster is malfunctioning. When i turn on the car, my fuel and RPM gauges show the correct information but after 2 seconds they fall to mark 0, only works the speedometer and the lcd display with the warnings lights. I made the Cluster Test and it past the test perfectly. I have the BC Indicator Stalk broken and the exterior temperature sensor missing. Can those parts cause the cluster failed after 2 seconds after start? I reseted the car with a scanner Disconnected the negative connection from the battery Disconnected positive and negative connection from battery Checked all fuses and Relays Made a reset from the occults options of the Cluster Made a test from Test option of the cluster Disconnected the cluster and connect it again. Checked some grouds wires whithout good results
Bill Boyd
Level 3:
Top Expert:
  • BMW Master 53,816 Answers
  • Posted on Jul 19, 2013
Bill Boyd
BMW Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950705
Points
172802
Some cpu units require a fully operational alternator for everything to work as it draws directly from that source of power. The cheapest course of action would be to have that checked out first
  • Martindk
    Martindk Jan 22, 2015
    It charges 146A - everything on + 2000rpm.
  • Martindk
    Tried resetting with the charger on supply - no luck. Any other suggestion?
1helpful
Where is exact location of taillights fuse of bmw 318d e90 2007?
https://fuse-box.info/bmw/bmw-3-series-e90-e91-e92-e93-2005-2013-fuses-and-relay
Where is the fuel relay on a bmw ?
It is under the hood in the fuse and relay center.
3helpful
2answers
2007 BMW E90 radio mutes every 10 seconds for approx. a second. Any ideas?
My wife's 2006 e90 has this problem too is the problem in the radio unit or in settings can anyone help please ?
Bmw e36 318is 1997 instrument cluster help needed.Went dead while driving....now petrol and temp/guage not working.....What can i check? replacing the tem swicth and termostat
CHECK 5 AMP FUSE TO THE POWER DISTRIBUTION CIRCUIT WHICH SENDS POWER TO THE INSTRUMENT CLUSTER.IF FUSE OKAY.EITHER CLUSTER HAS A LOOSE WIRE OR CLUSTER SHORTED OUT.IF CLUSTER IS FAULTY. THE BMW HAS TO REPLACE THE CLUSTER BECAUSE NEW CLUSTER HAS TO BE CODED TO MATCH THE VECHICLE.
What does a BMW 2006, 325i alternator warning light look like?
Hi rs11126,
If your charging system has a malfunction, you should see a red icon that shows a battery symbol with a - and + sign in your cluster. It has been used in most of BMW vehicles as a warning indicator.
WHAT STAND FOR WBAVA71058VE31197 FOR CAR BMW
WBAVA71058VE31197 is the Vehicle identification number for your car. It is for a BMW car, Series: 3' E90, Body: sedan, Model: 320i, Region: Europe, Production Month: 07/2007, Engine: N46, Steering: left hand drive.
3helpful
2answers
2007 bmw 525xi turn off service light for rear brakes
to reset light brake sensor must have been replace close door turn key on but dont start car when time is displayed on instrument cluster press and hold button on left side of cluster a orange triangle will appear keep holding next service function will be displayed release button to scroll through services that can be reset just push button again without holding when rear brakes are displayed on cluster press and hold button again the message reset with a question mark will come up release button and then press and hold again and light will reset
9helpful
3answers
How do I reset the oil service meter on a 2005 bmw x3
On the instrument cluster in the center there are two buttons (clock and s/r) .Press and hold the s/r (i think thats whats on the button) and turn the key to the first position. at first it will say TEST in the cluster. keep holding the s/r button and it will flash to your SIA (service meter) release the button and press and hold until it says reset (or reset flashes) and then press again. just play with it im going off of memory. just dont be afraid. as usual im sure your local bmw dealership would be glad to help
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
