Sea-Doo US 2013 GTI Limited 155 Logo
Anonymous Posted on Jul 16, 2013
SeaDoo GTI Limited 1998
Ive got 2. One won't do more than 25mph. Changed the plugs no difference. The other makes a awful squealing sound when you hit the start button, but doesn't crank. Ideas??
Jeff's Garage
Level 2:
New Friend:
  • Expert 118 Answers
  • Posted on Oct 23, 2013
Jeff's Garage
Expert
Level 2:
New Friend:
Answers
118
Questions
Helped
62338
Points
166
My 1999 Seadoo GSX Limited is having an issue the blige screens are leaking back through. THANK YOU
Well, you are welcome, but I did nothing to make that happen! I suggest you sell that old piece of junk and get a new machine!
Why wont a1997 Seadoo will no turn over ?
Could be a bad ignition switch grounding out the ignition, loose wires, bad ground. If it will not even turn the crankshaft over, then I'd check connections to the battery, to the 'ground', to the block/head/?? and make sure the wires on the back of the ignition switch are snug in place. Does it have an 'occupant' safety switch that will kill the engine if you fall off? That may need to be checked also.
My lexmark t652 is making a squealing noise when printing
Try with another cartridge first.
Printer may have gears with broken teeth.
Oiling will not help.
Error code p1513 on seadoo 2008 gti
Had P1513 error code in Seadoo RXT 2005, means compass out of range, but this PWC has no compass. Read about the error resulting from bad fuel pump, that has no specific error code. After a while it developed fuel pump problems, changed it and the error is gone.
Ford escort fuel problem
have you checked the fuel filter
Hi ive got a escort gti 1998 mk7 1.8i zetec. when cold and get 2 about 40mph it doesnt seem 2 want 2 go any more and foot is flat 2 the floor. u bk of on power then the revs and speed picks up. sounds like...
the symptom you discribe sound like a bad throttle position switch.(T.P.S. switch) test, replace, and calibrate switch & prob should go away. good luck.
1helpful
High pitched squeal
sounds like the water pump bearing might be defective. best advice is to replace the pump.
2000 IMPALA MISS FIRE AND BELT SQUEAL
have you changed oxygen sensors? also check wire and plug on #2 I changed plugs once and got multiple missfires changed 3 plugs to a different brand and it solved the problem
2answers
Squealing coming from belts 1998 elantra
The belt isn't tensioned correctly. Spay some WD40 on the belt whilst engine is running. May cure temporarily.
Top Sea-Doo US Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Sea-Doo US Boating Expert? Answer questions, earn points and help others
